Bonjour from the land of the Cajuns
JMac
I am James McDonald, professionally I am referred to as Mac. I have been working in watch repair for a little over a year. Before that I was a hobbyist. I work at Edwards Custom Jewelry in Alexandria. I am doing basic watch repairs on quartz and mechanicals. I have done COR work for customers on 3-Hand manuals, Automatics, and day-date complications. I have done very minor work on chronographs. I am looking forward to the entire level 5 course being available
1 hour ago, oldhippy said:
Thank you for your introduction and welcome to this friendly forum.
Do you work on watches using your microscope or do you use an eyeglass?
I use both daily, sometimes I like having the birds eye view. Especially when inspecting.
  • 3 months later...
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
