Hello!
Watch lover and hobby watchmaker here! I'm focusing on restoring my "heirlooms" and building new watches from old parts.
Feels great to be here!
- Jacob
Thank you for your introduction and welcome to this friendly forum.
Austria is my favorite country. Many years ago I stayed at St Wolfgang with my then wife. Also had a holiday at a place called Seefeld. How lucky you are to live in such a wonderful country.
Welcome.
I recently joined this forum and they have already helped me through two problems. You will not be disappointed in the quality of advise you will find here.  Good luck with your restorations.
  • 2 months later...
