IWC 1871: How to open the case?
Hoe
Dear Watchmakers
I purchased an IWC Ref. 1871. It seems to be a true project I am looking forward to work on.
But the first and probably major problem for me is to open the case. It is a square case body that has cut outs in the corners of the back. Each corner has a tiny bore, too.
I did my homework and searched for information online and found a discussion on the Omega forum about the same topic with some hints but with no real result for me. Hints: the case is the same as the one on the “Zenith Respirator”, it works with spring-loaded pins, URL:
https://omegaforums.net/threads/iwc-case-problem-how-to-open-help-needed.16751/
On a website of a dealer I found an image of an opened Zenith case. I can see bolts on the sides of the inner part of the case that contains the movement, URL:
https://www.vtgwatch.com/zenith-respirator-luxe-automatic-28800-date-vintage-watch-vtgwatch.html
Does anyone have some experience?
Best
Thanks, I have found that website as well, but the writer does not explain, how he opened the case.
He did not answer the same question that was also asked by a website visitor in 2018 (see comments below the service walk through presentation).
This is where it is levered I would say. Gently try it with a couple of screwdrivers either end. These recessed parts of the case have been put there for a reason. However be careful because if the dial is tight or has a overhang it will be easy to damage.
I managed to open the case with tips from IWC specialists.
In short:
You have to push on the crystal to separate the case back containing the movement from the upper case.
In detail:
You do not need to push the pins back with screwdrivers. There is not enough space anyway, you need a lot of force and you end up damaging the case and the screwdriver. Furthermore, you will somehow push the case together instead of apart.
Expecting that everything will stick together since the last service is ages ago, I put a tiny amount of WD40 into the holes of the spring-loaded pins (see photo above), the space between the case parts and the slot between the crystal and the upper case. I let it soak for some time. Do not use too much WD40… this is watch making here.
Place the watch on its lugs on support blocks (e.g. wood blocks) to generate clearance for the case back to come out.
With your thumbs push gently on one side of the crystal at six or twelve o’clock roughly where the pins are located. Push on the stiffer crystal edge and not on the centre to avoid crystal damage. I could not find a potential replacement for the crystal so far.
The pins are chamfered and will be pushed back automatically from the force applied until the case back is separated from the other case part.
The watch has a split stem. To remove the movement from the case back, first remove the split stem with the crown.
I guess this workflow is the same for the case of the Zenith Respirator.
Happy watch opening!
Small correction to my technical drawing of section cut above:
The rubber gasket goes around the dial and is not placed between the crystal and dial as in my sketch. The previous watchmaker did a bad job by squeezing the gasket between the crystal and dial. This left black stains on it…
    • Just missed it! I have a donor movement on its way. But thank you for the offer--I'll let you know if I need anything else.
    • My latest. Timex 2465. Replaced the crystal, caseback gasket and spring bars. All in less than $5US. Added a gray NATO strap I already had in stock.
    • I have some Gruen 510's in my donor pile if you need parts.
    • I've been intrigued by everyone's input here...so I decided to give this a shot. I bought the"typical" Pearl watch-machine basket and trays, for about $65. The trays are good,..the housing is a nightmare ! Thought it would take the mixer off my bench at anything above about 200rpm. The housing is cast of course,..and it's not "true" at all...so the harmonic vibration was insane. So,..I bit the bullet and bought the Elma housing and top. Not the baskets though, as the Pearl one's fit the Elma. Saved a bunch there. The basket and lid came to about $80 with shipping. The opening in the Elma top is 8mm, and the shaft that came with my stirrer is 6mm. I bought a piece of steel tube, 8mm O.D., and 6mm I.D. Cut off about an inch of the tube, and drove the rod into it. Gives a really snug fit.... Lightly champfered the leading edge of the 8mm section, then lightly tapped it into the top of the Elma lid. Spins like a dream now So... I have about $240 total into this including jars and steel mesh for the wave breakers   I'm pretty happy Best to you all   Randy
    • Still haven't gotten around to getting stems or screws, but I did make my first attempt at polishing a case. I just used a soft mop and rouge to reduce my odds of ruining them, and I think they came up pretty nice. Also gave the crystals a polish on the same wheel while I was at it. They were both very badly scratched up. The one on the left is fairly beat up, but it'll still make for a decent presentation.
