Now that 's interesting Mark! :)
Indeed - it's something I would dearly love to learn but nobody has ever shown me.
Surely someone on the Interwebs can make us a nice Youtube vid??? :)
I know that you can bore a hole through glass with diamond paste and a copper rod in a vertical drill. Possibly a miniature version of this using steel pinion and diamond paste may work, as copper would deform too easily? It would have to be done in a watchmakers lathe and the drilling done by hand using a tailstock runner.
This is just my rambling thoughts on the subject.
Did you check the balance pivot with a high magnification loupe? They can bend and also 'mushroom' the tip giving the impression that its too tight in the hole..
Anil
Another fine and very welcomed suggestion, thank you. (This forum is better than brilliant!)
I have a Brunel Long arm Stereoscope with various eye pieces and can confirm that the pivots are, by far, much straighter than any politicians promises will ever be.
I am on the lookout for a Jacot tool, but the one's on Ebay etc either have something missing, or are damaged.
Len.
I have recently enlarged a jewel hole. I achieved this by using engineers pin gauges in a pin vice coated with diamond paste I then slid the jewel onto the pin gauge and gently spun it whilst sliding it back and forth. It didn't take very long and the watch now runs very well. I think a similar method could be employed here using diamond paste in the jewel hole and gently working the balance back and forth whilst slowly tightening the cock down!
Hi Maurice.... I'm attracted to this idea but won't using this wear the balance staff first? This may achieve the desired result with more clearance between pivot and jewels but you may not achieve an even surface on the pivot and this will cause wear down the road.
Anil
Just a little side note - there should be an amount of side shake as well as end shake. When reducing the pivot make sure it is taken down around 1/100th smaller than the jewel hole.
  • Similar Content
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
