introducing myself
nickb2
Hello all
Nick from canada
I am an automotive technician, and I have a bulova precionist watch that I would like to fix, so I consider myself mechanically inclined but do not know much about fixing watches but I am willing to learn
I must also say that I am french, so plz forgive errors in my writing
The stem snapped in the crown.
any help with this would be greatly appreciated, advice on where to find parts etc what tools I need to buy
thx
Nick
Hello Nick and welcome to the forum,   I have attached two documents which may be of some use to you as you enter the Horological world.  If you wish to try to save the crown and are unable to remove the broken stub it can be dissolved with ALUM . have a search on the site there are many posts regarding how it is done
1612608791_ToolsfortheHobbyist.pdf TZIllustratedGlossary.pdf
Unfortunately that might  work on brass parts, but not on stainless steel like the crown of the diver in question, and so many other nowadays, because the crown itself would be attacked. Below the full thread with the indications I gave to remove a flush snapped stem.
    • Nice interesting diver Razz, i have a sheffield dress watch, different movement altogether. Could be a wrong motion works part, how does the setting feel before fitting the cannon pinion, clutch and intermediate wheel meshing ok ?  The less traditional setting design could be suspect, the second wheel has a slip clutch assembly, that most likely needs looking at. LA is 42 ° Razz Tbh i  much prefer to call the complete unit the lever, then use the seperate names for all of its components. Such as guard pin, fork, fork horns, fork slot, lever arm, pallets , pallet arms, pallet slot, pallet stones. I suppose pallet fork is the combination of the two opposite ends that make up the lever, its also called the anchor which is descriptive of its appearance.  Its a pretty basic 1930s  swiss lever movement H and yes Nev was meaning the pallet fork.
    • The pallet fork should really be called a lever, English lever, Swiss lever etc but most people including myself call it a pallet fork.
    • Seiko have case numbers, I  can't see it on your photos.  If you can find that we can look for a genuine crown.  If not, you need to measure the diameter of the stem, the distance between the lugs and the depth of the lugs.  The case number will be something like this.
    • I'm not sure what kind of movement this is, but I'm curious to know if you're using the word "lever" as a synonym for "pallet fork"?
    • Actually kind of rough, maybe munute wheel pinion problems? Is the 2.73mm canion oinion which seems rarer and not availble on Cousins UK. The seconds hand works and suprising nice amplitude but don't know the lift angle and BE this one says 17 j but is a pin pallet as well. Cap jewels on the escape and drive train pivots. Interestingly in has both water proof and shock resistant on the caseback and dial. Puts this around 1969 or '70? The double bezel that works independently is cool has the pi symbol on each. Wonder if it can be used like a slide rule ir something...
