Kienzle 606 problem
MiD
Hi, I'm looking for a Kienzle 606e movement.
I have one, but it's damaged, and I don't know how to fix it. It's something about the spiral that doesn't work. If I push on it, it runs...Thanks for support.
In the image attached you see, when i give some pressure on the element with a pencil, the movement starts running...you might notice that the wire around the element seems to be damaged. Does somebody know if it's possible to fix this part of the movement?
IMG_1134.thumb.JPG.68287ec957dfdc4bfbc5b13edb1a055f.JPGIMG_1133.thumb.JPG.2b3c4437d57ae4e6cac81141af64ab10.JPG
German alarm clocks aren’t my specialty, but what you are pushing at is probably the click and what looks like a mess is the click spring.
What probably happens is when you push at that spot you probably release the mainspring somehow and it powers up the drivetrain temporarily.
So I think what your clock needs is a good cleaning and lubrication afterwards.
Of course one could fix that click spring while you at it.
Hi HSL. I have discovered more problems with this movement:
I've realized that the movement spring is missing...Also, the spring attached to the clockwork gear wheel is damaged...See images. I'm trying to get the missing pieces. Could you help me with this? I think I need a new mainspring and to fix this tiny wire that pushes at that spot.
I haven't found such a movement to buy online...
Br, MiD
I took  look too, these seems to be thrown away hence the lack of spare parts.
But at ebay.de I found an Ankra with the same movement in it.
https://www.ebay.de/itm/223952948209?hash=item3424a2cbf1:g:IlgAAOSwfZpedgXA
unfortunately there isn't any specific spareparts right now.
https://www.ebay.de/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=kienzle+tischuhr+teilen&_sacat=0&LH_TitleDesc=0&_odkw=kienzle+tischuhr&LH_PrefLoc=2&_oac=1
ok, thanks for your help. I'll have a look at it.
"ANKRA Tischuhr Buffetuhr Kaminuhr mit Kienzle Automatic Uhrwerk Unadjusted 606h".
I'm not sure if the 606h is the same as 606e though...
All I need is a spring...Isn't it possible to find a spring to insert (see photo), I thought those parts are standardized?
Edited by MiD
I have one of these clocks under the brand name"metamec"  Its a few years old.
The principal is the battery drives the gear work and drives the winding pawl assy, this in turn drives the mechanism at the same time the driving pawl pushes the main wheel. As its driving the wheel and the pawl is moving its winding the spring, on reaching the end of travel the pawl disengages and flies back under tension from the previously wound spring and the whole sequence repeats its self driving the clock. The problem I had was the pawl spring broke and it was skipping the main wheel.
I have not seen another clock like it or any data on it. It dates from the 70s was my Mother in Laws clock and It is only run in frequently
I found this movement very interesting so I fixed one of them, it was actually just a cleaning and some lubrication. Old batteries had let some juice out.
The solenoid kicks/winds the clock up, first of all make it sure it works, i used a bench power supply but you can use a battery pack (polarity does not matter):
https://youtu.be/NdK2gzyJ7q8
Here you can see that the clock is closing the electrical circuit but there is no battery (power source) attached to the clock so it stops. Then (unfortunately you cannot see it) I add power by using two wires coming from my bench power supply to the clock by briefly touching the movement with the wires (1 on the solenoid 1 on the base). So the solenoid kicks in/ winds up the clock.
https://youtu.be/lFgZatjqGFc
In its case with battery:
https://youtu.be/mUs4BwYZmVE
You can be the battery by yourself:
https://youtu.be/lBWK4GOKeOo
I have never seen spare parts for them, but they must exist in drawers somewhere long forgotten. Most ppl would not appreciate these movements so you could buy them for peanuts if they reach the well known auction sites. Only issue that ppl would list the clock without mentioning what movement it comes with.
Best regards,
lui
I also have a Metamec with this same movement. I picked mine up at a car boot sale for a couple of pounds because the movement intrigued me, and I can date it accurately because it was a presentation clock with an inscribed plate that reads "PRESENTED TO W.O.II A. HARRIS BEST WISHES FROM FELLOW MEMBERS SGTS. MESS A & S. H. 1966", A & S. H. being the Argyll and Sutherland Highlanders.
Having serviced the movement it is now running well and has deviated by less than 15 seconds from my radio controlled reference clock over the last 10 weeks. As well as being a self winding movement I believe that the design also lends itself to a very consistent rate by virtue of only winding the main spring through half a turn. It does this approximately every 3.5 minutes courtesy of the soleniod kick as described by @luiazazrambo above, and because such a small part of the main spring is being used it delivers very consistent torque over a given period of time, reducing isochronism errors considerably. Also, being a clock and therefore not changing position, positional errors don't apply, which means that it keeps very good time. You just have to get used to the sound of the soleniod kick going off a bit like a camera shutter every 3.5 minutes.
Hi
thank you all for reply.
I didn't really understand though, whether it is possible or not to repair the spring as shown in my photo above...?
To wait for someone to show up with spare parts doesn't seem to make sense...
Greetings
Hi
I didn't really understand though, whether it is possible or not to repair the spring as shown in my photo (1)...? The loose wire must be wrapped around the axis again and then fixed again > See stills (2 and 3) with red arrows from your youtube video (@luiazazrambo).
1094203571_Bildschirmfoto2021-06-26um16_51_45.thumb.png.6bf3f72a1f37823c27ba0a3ae37c51f4.png2022343089_Bildschirmfoto2021-06-26um16_50_26.png.fcddc0c60611250e251bfed9325a4c2f.png
May anybody give me a support in repairing this part?
To wait for spare parts to show up doesn't seem to make sense...
Greetings
Hi  Thats exactly what happened to mine , the spring broke. I was lucky enough to have a tin of coilsprings from my office machine mehanic days and modded on to do the job. I thing if you look on the ebay you should be able to pick up assortments of coil springs, so measure yours   mm/swg  and have a look its not too difficult to make one to fit providing you have the material.
    • @JohnR725 has pointed out many times that the Swiss don't care about amplitude, the timekeeping is the most important.  Give yourself a  pat on the back, great beat error and timekeeping, nothing to be disappointed about.
    • I'm bothered but I agree he's a busy man and I don't want to bother him.  In the meantime, we really do need to have other ways of contacting each other
    • This is as complicated as epilame, too many unknowns. The life expectancy in the UK is circa 80, so most people from 1944 or earlier are dead.  Assume they had children at circa 20, they died in 2004. Their children started selling 1944 watches in 2004, so pre-1944 watches must be getting more rare.   It doesn't work though because as you stated some were sold as tat, but since watch prices have increased people have decided to sell when they may not of done in the past.
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
