Main Spring Winder
RogerH
5 hours ago, RogerH said:
Hi Folks, it's the same old topic that keeps coming up but as it's one of the most potentially dangerous part of clock repair I always think it's worth a visit just to get peoples opinion on what is best.
I've just seen this on Ebay....thoughts please -
https://www.ebay.co.uk/itm/303954191633?hash=item46c514e511:g:940AAOSwLG9gjRC2
I have one exactly the same, it's the Ollie Baker style.
Mine has been used on Westminster chime clocks and 400 day clocks, not tried it with fusee springs, because I haven't worked on one yet.
The winder MUST be clamped very securely to the bench before use, mine is held in a large woodwork vice.
Bod
1 hour ago, oldhippy said:
This is the sort I had and it will remove the biggest fusse springs and put them back in. Just make sure you have a good bench vice.
 https://www.cousinsuk.com/product/mainspring-winder-bergeon
On this style without the retaining barrels, how do you hold the end of the spring when transferring into the barrel?
51 minutes ago, RogerH said:
Thanks OH, that does look a bit more like it. does it come with the barrels? or do you buy them separately.
You don't need barrels with this type. You wind the spring up inside the barrel and unhook it with a pair of pliers, I used long nosed ones. Putting it back, you wind the spring up enough so the barrel goes over the spring, making sure it hooks on the inside, you switch the click over so it unwinds and you are finished.
Ha,ok, that's what I thought. Ever have one slip out of the pliers? ?
Not wishing to start a new topic but on a similar vein regarding Main Springs I recently had an Ansonia mech in with two broken main springs - not too sure of the story behind it but they were both split in various places. I replaced them both with new springs of matching width and depth - a bit hairy hence my first question about winders! but it all ran and chimes very well, however, the chime train runs down very quickly - about 3 or 4 days where as the time train appears to be a standard 8 day.
Is there a difference between the springs? They both looked to be the same. is there something else which might cause this? or do they often wind at different rates. I've attached some before pictures. stupidly I didn't get any after ones but it cleaned up really well.
The springs should run down at the same amount if the clock is 8 days the time should last for at least 8 days and so should the strike. Both springs should be the same size and strength. Are you sure the strike side isn’t acting up such as striking when it shouldn’t, striking more then the designated amount.
Hi OH, no, it chimes perfectly. I completely stripped and cleaned the mech and manually wound through the hours with the strike hitting the hour and half hour perfectly. When it's running it's running fine but after three days you need to give the chime side an extra wind up. as the time train runs ok I can only assume the size and strength of the spring is correct. I wonder if there could be some drag causing the chime spring to have to work harder? I didn't see anything originally but I'll strip it again and have a look.
No, it seems to run down quicker. So it's unwinding correctly but at a faster rate than the time side. Thinking about it, I wonder if it's not unwind completely. May be it's sticking so it's not the strength of the spring but something that's causing it to snag and not unwind fully......I'll know more when I get it on the bench.
I think I can now close this topic - unless anyone has any other advice on winders - but I got the Ansonia mech on the bench and looking at both springs, when I fitted them I didn't have the ends fully down against the plate so as the spring unwound it was rubbing against the wheel. I've attached a pic to show the mech with the springs now in place and an arrow pointing to where they were. I'll keep it running but I'm fairly confident that was the issue.
I suspect they used an incorrect key at some point (Or pliers!). The key with it now is worn but it works well enough. The fact both main springs were snapped suggests there's an interesting story to tell but I guess I'll never know!
Another question on this topic. I'm working on a clock with two barrels both appear to have thr spring soldered in place! See pics. The whole clock was very gunged up so I would like to clean the springs but not too sure how to if I can't get the things out of the barrel.  Any thoughts?
    • Couldn't see it on the tech sheet , picture is a bit fuzzy though . Is that to keep the pinions pressed on Marc ?
    • Doctor, If the train turns when hands setting, this means that the train is not blocked. And this is true for all kinds of trains design. The train is normally blocked by the lever. So, put the lever in place and try again. If the train turns again, search where You have placed some wheel upside down and it is not meshed with the next one in the chain. The other thing is the amount of friction that is needed to overcome when setting hands. Yes, the friction part here is in the great wheel, and it needs lubrication. If the parts are dry, then friction will arise, seizing will happen and thus risk of breaking of teeth in the train or breaking of joint wheel/pinion. I don't know this calibre, but I guess the clip is part of the friction device. But for sure it stays tilted, which is not normal. So, pay attention to it and see what is wrong there
    • It most certainly should be there, but it should fit better than that. Here is what it should look like.
    • This way is dangerous. The problem is that the collet is not expected to be perfect in this tool and the wheel used for the grinding is big and easy can touch the balance wheel. Can You show the bottom side of the balance wheel?
    • It shouldn't be attached    The pinions look independent of each other, not in alignment,  but the clip is bothering me or have you just placed that on the pivot end?  Found a cannon pinion maintaining clip in the tech sheet, is that the disk on the end and is broken.  Whatever happened to exploded diagrams 😠
