Another new member
tman
Hello.
Another new sign-up here.
I'm an IT bod by trade and I spend most of my spare time restoring vintage cars these days.
In a past lives I've been a draughtsman, electronic technician, TV engineer and worked a while in laser printer development.
My downfall if you will is, if I have a faulty 'something' in my life I have to take it apart to try to fix it, I can't help myself! I'm moderately successful, mostly down to determination and stubbornness rather than any outright skill-set on my part!
I've spent a few weeks of evenings watching Mark's YouTube videos and they inspired me to dip my toe into horology.
Where this will take me I don't know. What I've realised fairly quickly is that for this to be a lasting hobby, I need a microscope - eyeglasses are going to become tedious for me very quickly.
My order of tools from Cousins arrived last week. I compiled my shopping list while watching videos but I have to confess that since this is yet to become an 'official' hobby, I kept it pretty much to budget/no-name brands.
Anyway, that's all from me - I've need to go and write up a post asking for help from you good people!
cheers
andrew
Thank you for your introduction and welcome to this friendly forum.
A good screwdriver set will make life easier than cheap ones  the same goes for tweezers.
This set is good to set you off
 Bergeon 30080-P05 screwdrivers
Dumont tweezers No 3
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄      I think I have been on this forum about 4 years and still yet to really strike a blow. That's a bit sad isn't it. Signed up to Mark's watch course and have yet to buy the movement for working on. Have most of the tools I think I will need so now all just a matter of will.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
