Removing stuck screw in barrel arbor
The screw was stuck in thus pocket watch arbor. Despite leaving it to soak WD40, I managed to shear off the screwhead. Is this the sort of thing alum would be good for?
Also, any idea which movement this is? - it is marked as ASSA on the mainplate and the only number is a 2 stamped somewhere else. I understand that ASSA is the same as A Schild (AS) but there is no movement number 2 showing up on Ranftt.
Edited by Bonzer
spelling correction
  • Bonzer changed the title to Removing stuck screw in barrel arbor
Hi  Alum will be a non starter as it eats steel alternatives are a new arbour or drill it out, or use a screw extractor.
some of these screws are LH thread.    attached is the screw extractor. As for finding the details of the watch try pocket watch database. Mikrolisk which gives makers mark info.  cheers
I've since managed to extract this screw. What are my chances of obtaining a replacement, do you think?
The screw head is 3.4mm dia
Thread LH 0.95mm dia, 1.5mm long
Is there a supplier that would be able to help?
Thank you jdm. I was aware that Cousins sold an assortment but I wasn't sure if it might be possible to order specific sizes from somewhere - although I can see why materials houses would perhaps prefer to sell an assortment.
Thanks for the links ?
It's extenuating to try to buy a single screw, which is then paid a lot more per unit, heaven forbids one breaks or lose it again. What we could do is to buy or sort some assortments individually and then sharing on a running thread what is available for free to other members. I will begin with Seiko 7S, and Swiss setting lever screws, hope someone else will follow.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
    • This watch was damaged when I got it. I didn't break the escape wheel pivot, and I bodged a fix with epoxy to see if I could get it running. I'm not yet ready to get into lathe work, or shellacking jewels, and may never be. But I'm learning plenty with each watch I tackle.
