Omega 55* seconds pinion oiling
JohnC
Hi folks,
I am working on an Omega 552. The basic movement is together and running fine, but I now have to add the seconds pinion, which is held in place with a small spring.
I have been told elsewhere not to oil the back side of the pinion, where it contacts the spring. OK, but how about the bushing side? Can anyone advise about this? I know at least one person here has posted about the 500 series before, but I cannot find the thread.
I have found documentation for this movement (or, to be precise, the 551 - which I believe is just the chronometer version of this), which discusses the automatic works in detail but does not give advice about base movement oiling.
Many thanks in advance.
Edited by JohnC
Typo
I wouldn't listen to whoever said that ?  and oil & epilame.
35 minutes ago, JohnC said:
Hi folks,
I am working on an Omega 552. The basic movement is together and running fine, but I now have to add the sub-seconds pinion, which is held in place with a small spring.
A sub second pinion on a 552?
Forgive me, but I thought this was a centre seconds sweep second movemnt?
One of the problems we have with this is Omega is not entirely helpful. If you look up the 552 they will refer you back to the 550 and if you download the tech sheet it's only the parts list. Then unhelpful it refers you to another document where they group all the common things together. But that does not have lubrication of the basic caliper only specialty items and this is not considered a specialty item.
One of the problems subjects like this are hard to find on the discussion group of fast discussion is how would it be titled? I know we have discussed it before just not finding it. Also the other problem is there are variations to this part. In other words some of them have an upper pivots in a jewel which you probably would lubricate but would you lubricate the spring for instance? So conveniently are not finding anything at all.
363_Omega 550 NewLR cousins UK.pdf
Seem to remember that the spring should not be over lubed.  i gather there needs to be some friction to stop it overrunning as it ticks over but not too much to make it judder.
I have a note from somewhere I can't recall where (possibly from Cal 1022 which apparently may be similar to 550 as scribbled on same piece of paper!!), which states,
"Adjust it (the spring) so that it has enough tension that once you lift it. the gear train spins just a little but not too much when the pallet fork is out.  You want the centre (second?) wheel to turn about about half a rotation when you do this. You want to get crazy,  epilame those two parts (spring and pinion) and a little 9010 will keep you out of prison",
Wording in brackets is mine not in the original note !!
Hope this helps a little.
Edited by canthus
I had the same dilemma with my cal 565. I ended up putting the tiniest smear of oil (9010) under the spring.
I hate those springs - very easy to accidently bend, and then break, trying to get the correct pressure on the pinion. And of course, being Omega, not cheap to replace.
Too little pressure and the second hand judders, too much and it kills you amplitude.
@canthus your past self was wise to write that down! Many thanks. @mikepilk yes it's a slightly annoying system - going to be more so when I have to put the seconds hand back on. @JohnR725 yeah, the documentation is pretty obscure on this point. What I am hearing here is lube both sides with 9010 very lightly. Seems like the right intuition to me. If I hear differently I will let you guys know.
From a respected (WOSTEP) authority: low-torque oil on the bushing side, no oil (or extremely light) on the spring side. The spring should be tight enough to gather (hold up) 1-1.5 turns of the fourth wheel when the pallets are removed and you wind the ratchet wheel a few clicks.
  • Thanks 2
  • 2 years later...
Oh dear. I didn't think this element was so tricky. Good that I have this heads-up and before re-assembling.. thanks!
Alright. So HP1300 for the bushing-side, I guess. I'm a bit surprised (would have used 9010), but ok.
Thanks for sharing!
Well, well, well, I thought I had finished my service of the 551...but the seconds hand ruined my day. It's stopping, ticking, jumping all over the place. I definitely bent the pinion spring 😖
I found this video -- indicating the correct angle of the spring. Maybe helpful for others.
I'll try to get the correct bend at some point this weekend and will report back. Wish me luck please.
Thanks for sharing!
Where did you see to use HP1300? I've only ever used 9010 on centre seconds.
My bad.
I was sure I had read that recommendation in this thread, but I don't see you now as I look back. I was actually assembling the seconds pinion on my 552 yesterday night and also used 9010. Makes more sense.
Pheeew, I managed to bend it into shape with two tweezers. Nerve-wracking...
But it worked out and now it's sweeping nicely without any effect on amplitude.
I'm very happy.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
