Pocket watch history
Definitely following this!
May I ask, could you possibly take a few more pictures: close-up of the back plate, and of the works from the sides?
Can you tell if the signature reads "W. C. Davies" or "W. G. Davies" or what it might read?
I'm thinking it's likely fuseé and English lever.  Nice swing-out case!
Welcome to our forum by the way!
Addendum: does it read "Mountain Ash" in the upper left?  Or what does it read?
Edited by KarlvonKoln
Made an addition
I think Clockboy made a really good guess on year of manufacture.  If I found the right guy, he would have been born in 1853, so in the mid-1870s he'd be in his early 20s.  He *could* be a [random number] generation jeweller/watchmaker and thus could have apprenticed for several years prior to making your father's watch.  Hard to say how many he made, let alone how many survived to this day.  Was your dad born in, traveled to, or stationed in Wales or England?
Further research hasn't turned up anything more.  Thinking on it, being that he advertised as a jeweler first and foremost, there is still a chance Mr Davies engraved his own name on the watches he sold, but perhaps did not make.  But it is still possible he made it.  Either way, let us hope it never needs a replacement part.
Hi and welcome to the forum.
If you post a photo of the hall marks on the case (or you could look them up online) this can be dated to the year the case was made also the case maker, not always the same people, does not necessarily mean the movement was made the same yours but it is more information for you.
Graham
Thanks for the feed back, very interesting. I have added a few more pictures.
and unfortunately it does need a fusee chain repair, see chain in case back picture. Any ideas who may have the skills to add a new hook?
Thanks again for the info ..
I have not found a info of repairing the hook. You might have to purchase off eBay a new (used) chain or part of a chain that has a hook. The repair to broken chains is via riveting. When I repaired a very similar pocket watch I cleaned and soaked the chain with paraffin so all of the links were really free and lubricated.
On YouTube this is an excellent vid by Richard Perrett servicing an English fusee pocket watch. Also ironically showing how not to break the chain.
    • My mentor has been using one of the Chinese clones for several years. Seems to work very well. Just put the object you wish to demagnetize in the centre of the cross and press the button. One word of caution though, the quality and QC of Chinese clones can vary a lot. You'll never know whether you got a gem or a lemon.
    • You could also use a very fine artist's brush to brush between the coils.  If you get a size 00 or even 000 that should be small enough for convenience, and with bristles so fine that they are incapable of damaging the hairspring.  Get a good one though, like Windsor-Newton or similar.  I have never had a Windsor-Newton brush shed on my art or other work.  You want a soft brush that will not shed.
    • Sounds interesting but how do you push the button if you’re holding both ends? the large current draw overheats after 3-5 seconds and the thermister triggers. A great tool for magnetizing things but I’ve not be able to ever demag anything with it because the emf is so strong it pulls the item off center (down or up).   I paid $89 bucks for it from  CAS-KER, if someone on the board wants it I’d gladly sell it for $25 plus shipping (probably US only otherwise postal costs are prohibitive). Just sent me a note offline.
    • Hi. First thing to do is measure your oil movement as the vx32E and the 43 look very similar but one is a couple of mill smaller the vx32E.  Also the canon pinion heights differ attached tech sheets for 7N22. And  VX43, check details on the sheets. 7N22A_29A_33A_42A_43A.pdf VX43.pdf Hattori VX32E - Specification.pdf Hattori VX32E - Disassemble.pdf
