Old Medana...eratic timekeeper!
I guess I was hoping for a simple fix, but you guys are all over this which is brilliant, but it's making me worried that I'll end up with an ornament that doesn't even tick!!
I'm tempted to adjust it for one position and walk around with my arm in the air all day!!
4 minutes ago, RichParker said:
Ok, So my last post was incorrect.
I had best leave it then.
The wheel is a bit wonky isn't it! Maybe it's out of balance? This is all way beyond me and my capabilities tbh.
Not if you have the right tool.
I would tend to leave well enough alone. Putting a cylinder balance wheel in a truing caliper you going to have issues. If you break the cylinder it's going to be really fun to try to replace that and fun really isn't quite the right word. That's a cast balance wheel it wasn't machined. It probably had some machining but? I was trying to avoid this this is not a real high quality watch if the hands move and keeps time within minutes per day you should be happy.
Thanks John, I guess I know my level of 'expertise' and limitations, so I think you're spot on.....I will leave well alone and accept a few minutes. And you're right also in that it doesn't look great quality in truth, so I shouldn't expect too much, especially with its undoubted age and wear.
Cheers guys, great to get your thoughts and to tap into that knowledge. One thing I've learned since I started dabbling and tinkering......this little corner of the world is colossal!!!
I would certainly agree with JohnR regarding the regulator. I have seen these single pin regulators before but only on old cylinder movements, the spring rests on the pin and effectivly shortens/lengthens the spring when the regulator is moved as far as I remember it doesn't  beat  between the pins.
This is a more common design than you may think.
Taken from the Timex service manual....
Edited by Marc
typo
    • Hi everyone, I put together a Venus 178 recently, but found that the hour counter "creeps" ie. runs when the chrono is disengaged. This is the similar type of setup as the Omega 861, where the hour counter is driven off the mainspring barrel, but stopped when the chrono is disengaged by a friction spring.  Am I correct in assuming that the friction spring for the hour counter driving pinion should be dry? I am guessing that the issue will be either the spring or the driving pinion, but while the driving pinion has some wear the spring looks decent.  I've attached a couple of photos in case anyone has any tips. Thanks in advance!
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
