Watchmaker lathe head
Welcome to the forum. Are they the same movement?
By rottobotics · Posted
I appreciate the suggestions. The o ring was hardened and Cousins would have cost $13 shipped, so I ended up sanding and filing a 2mm ID, 4mm OD down to size that I had around. The washer wasn't going to stay in place on it's own, so soldered it. I hadn't thought of that before, so thanks for mentioning it. If this fix doesn't work out, it looks I should probably just replace the whole crown. -
Dear sirs, I have an Omega pocket watch with movement serial number 4480628 and the balance spring became torn as the picture included below. I've got a similar movement for spare parts but it is from the next series (5023967). Do you think the spring might be compatible? Thank you for your help! Best regards, gerardo.
By Senyamnesi · Posted
I had to deal with the same battery confusion on my old Casio. For the AQ-321G, I used a lr41 battery equivalent and it worked fine—no issues with fit or powering the module. Just make sure the contacts are clean and you haven’t lost that tiny spring during the swap, which almost happened to me. -
I swapped mine with a 377 and it's worked fine for over a year. Just make sure the contact springs are clean and sitting right when putting it back together.
