I broke my 4R36 hairspring. :(
Right the next thing is to verify that the power is being transferred from the mainspring. So take all power off the watch, remove the balance and the pallet fork.  Now put a turn on the mainspring, do the wheels turn freely right up to and including the escape wheel.  If that's ok, let off the power again and re install the pallet fork, now put two turns on the spring, manually move the pallet from side to side doe's it snap sharply from side to side when moved, if so the power is ok and the problem is most likely the balance.  Remove the power again and re install the balance, now without power when the balance is moved on its axis and released is it taking a few turns before it stops, yes/no, if no check the end shake of the balance staff, if yes remove the power again them remove the balance and the pallet fork, re install the balance and check the position of the impulse jewel, it should be central to the position the pallet fork is in when installed and central to the bankings. The previous information supplied will show diagramatically what I mean.      cheers
4 hours ago, Alexandros said:
Hi, so I replaced the balance wheel on my 4R36 movement with a NH36 balance wheel, idk what I have to do but it just won’t start running altough it fits perfectly and everythin, the hairspring is fine and is not bent at all.
Thread merged with your previous one on the same matter.
I had warned that getting a replacement balance would not have been the best choice for someone without any experience. At lest get some cheap but running mov'ts to learn first how to correctly refit, and handle in general, a balance.
On 1/18/2021 at 6:39 PM, Alexandros said:
I bought a new NH36 movement. Just practicing...
Have a look on the video below to understand why the impulse jewel needs to be in between the horns of the pallet fork. Then watch more videos like the ones by our Host Mark Lovick to see and mimic the moves done to install a balance it in one shot. If you are not successful at this, there are other methods too, often discussed - use the search function.
Right remove the fate complication and try again in case anything is causing a bind. what we are doing is reducing the watch to the basic mechanism.  Did all the check work out and there is power to the balance and with the power off the inpulse pin is in the center in the fork.
Hairspring coil is pushed to the side and not concentric, which leaves the last circle of the coil too close to the stud, upon expansion of the coil, last circle may rub on stud, get stuck  ......etc. So first thing to do is to get the coil centered and away from the stud.
Next feel the end shake.
Turn the balance wheel as you observe the fork, balance should come to rest where impulse pin is inside the fork horn " in beat", use beat adjustor arm to bring impulse in beat.
Let us know the result.
10 minutes ago, Alexandros said:
Is it possible that the mainspring is magnetized because the spring is on one side?
Magnetization does not stop a watch. Please understand that replacing a balance complete is not as easy as it may seem, it's very easy for a beginner to do damage and don't even notice. In these cases, the watch will not run, or run erratically.
this is why pictures are nice it allows us to see things that maybe you don't see?
casually your hairspring looks fine but?
overlooked as it's part of the automatic winding your magic lever is not where it is supposed to be.  I'm attaching a couple images one of them shows how it's supposed to be. then look at your image that I snipped out and added some lines in. They even made a nice hole in the plate so you can see that the magic lever is missing? having your lever on top of the wheel that it's supposed to engage with a cover plate pushing down on it probably not desirable.
Right remove the date complication and try again in case anything is causing a bind. what we are doing is reducing the watch to the basic mechanism.  Did all the check work out and there is power to the balance and with the power off the inpulse pin is in the center in the fork.
Sorry a typo shoud be DATE , in other words the date /day mechanism just leaving the basic watch plus the auto winder/magic finger assembly.
Hi Poljot's Picture explains it very well, The inpulse pin marked in red, should rest in the fork in a straight line when the power is removed and the fork/pallet is centerd and stay there if it moves either left or right on its own after being centered  the balance spring will have to be adjusted.
I can't take credit for the picture, but red rectangular and two red crosses are mine ?
 alexanderos, just for a quick test,   you can wind through the ratchet wheel.
Good eyes spotting magic lever JohnR.     however, coil is dangerously close to the stud too.
Regs
Joe
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄      I think I have been on this forum about 4 years and still yet to really strike a blow. That's a bit sad isn't it. Signed up to Mark's watch course and have yet to buy the movement for working on. Have most of the tools I think I will need so now all just a matter of will.   I have to make a crank handle for my Joe Collins spring winder as well and some spring retaining tubes as I can't find where I can buy them. I will be salvaging (here I go again) the aluminium tubing from my old hang glider which I have to scrap as I can't fly anymore and it is too old to sell. All the aluminium tubing is aircraft grade so I am hoping it will be suitable for the winder. I have also been making a bushing tool and I have just worked out that it will work well with my Dremel stand. So another thing that I can turn into a working tool. Don't know if you guys have ever seen the ad about the guy that buys himself a new 4WD and the son says "We're going to need a bigger boat." So Liz is looking at all the stuff we have to get rid of and says "We're going to need a bigger bin." Really difficult to work out how big a Dempster bin we need. Sigh.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
