Staking tool punches
2 hours ago, jdm said:
No. There are 4.0, 4.7mm, not sure what the American and Japanese are.
I have a Japanese MKS Meikosha staking set which uses 4.7mm punches.
Cousins sells the Bergeon punches individually and they are also 4.7mm.
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
