Quartz replacement?
IFELL
Hi all,
I am dealing with quartz Seiko 7N42 movement which I want to replace, but can't find any stock with the suppliers. Would you know about any suitable replacements for this one?
The dimensions are:
Size Ø25.60mm (11½’” Ligne)
Height 2.90mm
Hour, Minute & Centre Seconds
Date @ 3h
Battery 371
Hands Min .65, Hr 1.10, Sec .2
Thanks,
5 hours ago, IFELL said:
Hi all,
Thanks,
You can order the entire new movement for £10.45
https://www.cousinsuk.com/category/filter/seiko-movement-parts
They are out of stock till mid Dec, if you can wait.
The vx42 is a direct replacement, sold by Seiko for assembly into non Seiko watches ,as such it is marked differently. it is generally cheaper ,more readily available and the only time you would know the difference is when you remove the case back.
It doesn't look like a direct replacement, but close: Sec .18 Vs Sec .20
7N42   Ligne, 11 1/2.  Thickness 2.78.  Hands 65/110/20 Dial feet  1 x 7  cell 371.
VX43   Ligne 11 1/2     Thickness 2.92.  Hands 65/110/20 Dial feet  2 X 8.  cell 373.
So not directly compatible  so hang on in there for the correct movement. You would have issues with the dial feet and the height depending on the case depth.
VX42 was suggested, not VX43:
Height 2.62mm
Hour, Minute & Center Seconds
Date @ 3h
Battery 371
Hand Sizes: Min .65, Hr 1.10, Sec .18
1 hour ago, yankeedog said:
Please check my post  in watch of the day. Dated September  9.  I Put a vx43 in a 7n43 watch without  a problem.
I am glad it worked for you and I have no doubt that vx43 would work just fine in many case.
I simply noticed two differences: 2.92mm Vs 2.62mm Height, and Sec .18 Vs Sec .20 hand dia. I will take a look at your Sept 9 post. Cheers!
Thank you all for the discussion, I will try ordering the VX42 as the price is ok for giving it a go.
And yes the reason for this original question was the fact that the exact replacement is out of stock with not much visibility on the restock date.
Thanks.
Yes there may be differences in the height, the vx42 being a tad slimmer.It was my impression however that most, if not all recent Seiko Quartz movements had 1.10, .65 and .20 mm handsizes.
Some Seiko movements that I serviced were just under 2mm in height in very slim watch cases. Thus, I would not get any similar movements if they were even slightly thicker. Those movements did not have Sec Hand, just an Hour & Minute.  1.10mm & 0.65mm sounds about right, but I don't remember.
So, the VX42 did not work as the date ring of the 7N42 does not fit in there. I need to swap the disks due to a different colouring.
If you are not swapping the date disks, the movement swap would probably work.
So, I will be patiently waiting for Cousins to receive the movements...hopefully.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
