Balance tack?
KarlvonKoln
Made one of my own.  My remaining pieces of 1/4 inch brass were narrow so I had to adjust the measurements a tad.  But it functions very nicely.  I like that it supports the wheel at a predetermined distance and does not allow the hairspring to hyper-extend.  A nice tool in theory, and I plan to put it into practice and judge how often I use it and how it performs.  Thanks for all these replies to my query, folks.  You have given me the more thorough discussions I was seeking.
How did you bend the brass for the top lever?
First, I ground the underside part way in, to thin the arm just a little, right where I needed to bend it.
Then I clamped the long, thick end. I lined a pair of pliers with a strip of silicone from an old spatula, and applied light heat from a propane torch as I *very slowly* and gently bent it to the amount I needed.  I bent it against a wooden buck I'd cut for this.  When it got close, I then used a rawhide mallet.  I'd also drawn out a measured profile on an index card ahead of time.  I just bent a little, compared it to the card, bent a bit more, compared, etc.  I took my time.
Edited by KarlvonKoln
  • 3 years later...
On 11/27/2020 at 8:47 AM, nickelsilver said:
If mine ever disappeared I would stop work until I had made a new one, it's that handy.
I've come to the same conclusion.
After breaking ANOTHER pivot whilst trying to hold a balance+cock to adjust a timing screw, I decided all watch fettling was on hold until I made one of these thingies. I've wanted one since this post started years ago, but wasn't sure I had the tools to make one.
I still don't have a workshop or any workshop power tools, but the good news is I managed to lash this one together with just the following :  Vice, hacksaw, files, cordless drill (🤣), M2 tap and die, M4 tap.  Oh, and a blowtorch for bending the brass.  So I bought some 5mm brass bar and started hacking.
Without workshop power tools I had to improvise the hinge  (I just bought a small brass hinge) and the front legs (just M4 screws).
I couldn't have done it without @nickelsilver's plan and pictures. Thanks
It's not perfect, but I just tried it on a balance to change a timing screw, and it works. It's great.  I recommend everyone should have one. So buy some brass and start hacking. I can provide guidance if anyone needs it (but my metal working skills are pretty limited).
  • Like 9
You're going to enjoy using it. I've been using mine for just over 3 years now, and it makes working on balance screws so much easier. Between this platform tool and a balance screw holder, the work is barely a hardship.
Looks well made to me and deserves more respectable name than a thingie.
 If I try drilling one such hole, I'd probably end up with a black hole, the type that nothing can get out of. 😩
To try and get vertical holes with a cordless drill, I bought one of these, (only £12 from ebay)
In the pic it looks all metal, but I didn't read the ad closely enough, as the one I got the red parts are plastic. Still, it does help make the holes vertical... ish.
The spike with the thread to hold the cock, is made from a nail - turned to shape in a drill with a file.
The white plastic is a guitar pick.
7 hours ago, Neverenoughwatches said:
I might have found out what the pin at the front is for. Tool guide.
I spotted that one on ebay too
👍Mike you are nothing if not ingenious, you'll be deadly with a lathe 😅. I dont plan on spending the 120 quid if not more starting price on the one from ebay. At some point some bigger pieces of brass will grace my bench, either that or 1/4" mdf and superglue 😄
I don't think I've ever used a metalwork lathe - (as you) I have experience of using a woodworking one though! I took 'A' Level (remember them) Woodwork at school. I reasoned that I could always be a chippy if all else failed. Turns out that the grammar school I went to (rural Yorkshire) has a very good reputation, and I wasn't as daft as I thought I was. Ended up with an Aero Engineering degree and worked all my life in the aerospace industry. But not much hands on - I was mostly driving a computer.
Maybe that makes your self engineered collet/balance screw adjuster all the more impressive 🙂
    • @JohnR725 has pointed out many times that the Swiss don't care about amplitude, the timekeeping is the most important.  Give yourself a  pat on the back, great beat error and timekeeping, nothing to be disappointed about.
    • I'm bothered but I agree he's a busy man and I don't want to bother him.  In the meantime, we really do need to have other ways of contacting each other
    • This is as complicated as epilame, too many unknowns. The life expectancy in the UK is circa 80, so most people from 1944 or earlier are dead.  Assume they had children at circa 20, they died in 2004. Their children started selling 1944 watches in 2004, so pre-1944 watches must be getting more rare.   It doesn't work though because as you stated some were sold as tat, but since watch prices have increased people have decided to sell when they may not of done in the past.
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
