He all,
I can't remove this cannon pinion using my cheap presto tool.  It's smooth with nothing to grip on to.  I'm reluctant to get my hand removers under the pinion for fear of breaking it.  I guess my only option is to fork out for the Bergeon 4854?  I know it's an investment but it sure is expensive.  Any other ideas?
The other side has this hand setting cap, what's the correct term?  Without removing it I can't remove the bridge.  Does this pop off like a cannon pinion?
I don't normally touch pocket watches, but you know how it goes, friends and family ask so politely if you'd just "have a quick look".
Many thanks, Ash.
23 minutes ago, jdrichard said:
Crap....I forgot that move this weekend
Hah, yeah, I watched your video, then I had the same problem.  I'll try a pin vice later.
Any ideas about the other side?  That setting cap on the centre wheel will stop the wheel from being removed from the bridge.
What does the setting cap look like? Picture
Just had a look. That should come out with the center wheel.
Did you like the video? And, I did complete the job and the little watch is running really well and keeping great time. Just need to install the crystal when it arrives.
10 minutes ago, oldhippy said:
It needs to be knocked out with a small hammer.
That’s what I have done but was afraid to recommend that:) I did it on three Henry Peck pocket watches I have.
You want to give a quick smart tap right on the tip above the canon pinion, where the hand fits. This will knock the center pin through the canon pinion and start it out the back of the center wheel; this is usually enough to loosen the canon pinion and get it off, then the pin is a light friction fit in the center wheel. Usually on a watch like this you can do it without supporting the bridge side, but it's good practice to set it on a bench block or use a staking tool with a hole that will pass the square end of the pin.
As crown setting became more common this old system developed into the modern canon pinion everyone knows, but you will run into this system from the in-between time where there is no square and it's not immediately evident that it's a pin-through-center wheel arrangement. In cases where the center wheel is jeweled, invariably the bridge side of the pin will pass through the jewel, so you can remove the bridge. Do this, then support the center wheel on its pinion before knocking out the pin. The jewel will crack otherwise. Most of the time they are unjeweled though.
Yeah, I love your videos.  I like your narration and sense of humour, always a joy to watch.  Thank you.
Thank you very much guys.  All sorted now.  Once I understood the mechanics of the piece it was more obvious what to do.  I got it on my staking set and tapped it out, it was actually quite easy to move in the end.
A quick follow on question...  Since the centre wheel is friction fit (and doing the job of a cannon pinion) I guess it'll need a little grease right?  Just as you would a cannon pinion?
Thanks again everyone.
    • Some news. After screws removal from donor movement, a family shot. From left to right: original (broken) screws new screws purchased from Cousins UK, as "Slava 2428 clamp screws", that didn't fit. They actually & definitively look too large screws removed from donor 2428 movement Here we go! First one is in position: Let's continue on the other side: Done! Next step will be putting back the hands. Another discovery for me! I keep going ...
    • OK, I have been there many times and know several solutions. As I believe, the pinion (the part with the leaves ) is on the other side of the arbor, yes? If so, then there is easy way to solve the problem. You can grind from one side as shown on the drawing with dremel tool. This will allow to push out the broken drill bit easy from inside. Then You will be able to insert new pivot and then You can solder it in place and in the same time to fill the ground portion with solder. Of course, I mean solder for PCBs, but not the led free one - use led containing solder, the led free solder which is offered in common hardware stores is for idiots.
    • I think this is probably the part you were looking for but as it's a non standard Seiko Part Number there's no information on it. Maybe you could compare details with the Laurel @Embezelled has.
    • Purchased this today from a retired surgeon that said he couldn’t carry on restoring clocks any more in his retirement because of failing eye sight, he just kept bringing out boxes Pultra advertised as a 17/50 but turned out to be a 17/70 , 2 crosslides 3 tool rests fixed steady lots of collets , full set or step chucks, full set of ring chucks , full set of bell chucks plus loads more, he had a working mardrive as well but I said I didn’t want that but I did take the overhead gantry. That should keep me quiet restoring that according to my wife , she knows me so well after 50 years. Dell
