Hi all, I hope the fireworks exploding aren't making you jump when working on a watch.
I have an AS1187 movement, and in the technical data, it says 'balance cock clockwise,' - can anyone tell me what this means?
Regards.
Simply that the cock center screw is located clockwise to balance.
In case of balance cock clockwise, balance receives the impulse while turning in clockwise direction and vice versa for anticlock.
so it depends on weather the cock is mounted on left or right of the movement.
I see I could have said this more clear.
depends on ........       cock mounted on left or right of the balance wheel.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
