My First Project
azwatchman
Looks great! I'm still doing TZ Level 1 and will be sourcing parts to case the movement soon.  I'm going to go with the marine look for the 6498 similar to the picture below from a guy on instagram I follow.
10948757_1773711962854802_616550865_n.jp
Welcome to the forum from a classmate (I really don't say former since the course is for life, once you pay for it!). I took all 3 of them. BTW, is that the Chinese version of the 6497? How was it -- compared with the course's Swiss 6497 instructions -- different? Very nice watch!
Thank you for posting,
Cheers,
Bob
Cheers,
Bob
Is there actually different instructions for 6497/6498 movements?
Thank you all for the replies. Yes Bob it is the Chinese 6497, it is a Hangzhou. It keeps great time. I have a timing machine from Ace Timers. I have checked in all 6 positions and it's positional error is only 12 seconds. It seems to run about 2 seconds a day fast. Now I have only had this up and running for about a week, so only time (no pun intended) will tell the tale. As for differences between the Swiss and this one, there is o difference to the layout or the operation. As for the quality I am not qualified to speak on this matter as I have not had the pleasure of working on a Swiss. I chose the Hangzhou for price. it was only about $80.00 and If I screwed it up I would not be out the money. I will be buying an ETA 6497 of 6498 for a project now that I am confident that I can service it without damaging it. I am doing the TZ school second course and have just completed my disassembly. I bought a Hangzhou clone of the ETA 2836-2 with the day/date and autowinder complications. Wow, it is so much smaller than the 6497 that I have had to buy new loupes.
Thank you all for the welcome, I have been looking for a resource like this site while I journey down the rabbit hole of each collecting and repair.
William
Bob, no there is not. They use the 2804 but I found a great resource at Swiss labs (Swatch) and they have an animation that was you through the disassembly lube and re-assembly of the 6497.
That is exactly what I've been using even for my 6498.
    • I'll have a look for it, but don't hold your breathe. Failing that I'll make another video when another bezel needs to be removed.
    • The UK lots can be a 404 hit or miss, 6 - 10 watches can come in anywhere from 20 - 50 quid. I once had a 404 division of 8 watches for a fraction over 30 quid, one of them was a Smiths Astral model National 17 an absolute certainty for winner contender. The crystal was scrached up to the point of being very difficult to see the brand, something triggered a gut feeling in me and it paid off.
    • I just picked up this Mondaine quartz watch on tradera.com for £11. It's a non-runner so I will replace the Ronda movement (£10.95 at Cousins), polish the case, replace the case-back gasket, and replace the mineral crystal. Now, the problem is finding a suitable crystal. The original crystal is slightly domed (2.4mm thick dome), measures 36.4mm in diameter, and is 1.3mm thick at the edge. The closest I can get on CousinsUK is 36.5mm in diameter, 3.1mm thick dome, and 1.5mm thick at the edge. I think the replacement crystal would look OK, but the problem is finding a suitable glass gasket. The case diameter for the glass gasket is 36.9mm and the closest glass gasket I can find on CousinsUK is either 36.8x36.0mm or 37.0x36.2mm. I guess one of those glass gaskets could work but as you can see there's no way the 36.5mm domed crystal would fit the inner diameters of those glass gaskets. I guess I will have to give up on a domed crystal, no? So, the backup plan is to use a (1.5mm) thick flat mineral crystal as the diameters come in increments of 0.1mm. But, what glass gasket would be the better option? The one with an outer diameter of 36.8 (0.1mm too small) or the one with an outer diameter of 37.0mm (0.1mm too large). Again the case diameter for the glass gasket is 36.9mm. I believe I read or heard that the crystal diameter should be 0.1mm wider than the inner diameter of the glass gasket. Is that correct? I'm sorry for all the numbers. I've tried to make it as clear as I could. So, I'd appreciate your thoughts on this. BTW, measuring and sourcing crystals and gaskets is extremely time-consuming! 😓
    • Lots to choose from... Just sayin'.
