I have been searching for a Jacot tool but I have found  many come without a Bow.
My question is, I can purchase a bow from Cousins but it suggests   "Tie a piece of cotton string form both ends". Is this correct just thinking of its strength etc.
Edited by clockboy
That's what I do with mine - I use strong cotton. You would need to have just enough tension to drive the pulley and no more otherwise the cotton breaks real fast.
Here you are Mark, ten minutes work. This one is made with 1.6mm piano wire and I slipped a plastic sleeve over it. The ends were shaped cold with round nose pliers then trimmed. I used a very tough upholstery thread to string it and it works a treat. In my earlier post I suggested using 2mm piano wire, but 1.6mm works just fine.
That is absolutely brilliant Geo!
Mine is made of some really old bendy stuff - not sure what. But if it ever breaks - that's what I want :)
I mentioned this before but I can't remember to whom, but you will usually find a good selection of quality Jacot tools on the eBay.de (German) website. Pickings can be a bit slim in the UK.
If you are a BHI member then the annual auction usually throws up some good stuff.
If buying through eBay make sure the seller takes close up photos of the lanterns as they are often the first bits to get damaged - a mate of mine got stung in the past this way.
I had the same problem. The tool is in excellent condition apart from that and luckily the seller refunded a large percentage of the cost.
I got burned on two seperate sets with worn and totally unusable lanterns.
Hi Mark,
It was me that you directed to look at ebay.de
And I did find a beautifully complete Steiner Jacot tool that was in near perfect condition for $300US! I remember finding the exact same set on the current manufacturers website for almost $3000.
My only problem was finding a seller that would ship to the US as not many would...
Hi Mark,
Awesome!
I got my Elma Cyclomat from germany and a nice JKA Feintaster.
A couple of good searches:
http://www.ebay.de/sch/i.html?_sacat=0&_nkw=uhrmacherdrehbank&_frs=1
http://www.ebay.de/sch/Drehmaschinen-baenke-/74498/i.html
http://www.ebay.de/sch/Uhrmacherwerkzeug-/63200/i.html?_nkw=lorch&_frs=1
And if you want a great measuring tool:
http://www.ebay.de/sch/i.html?_odkw=feintaster&_from=R40&_osacat=63200&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0&_nkw=feintaster&_sacat=281
I just bought one this week from the bay, currently waiting for me at the sorting office, I wasn't going to use a note and just attach to a small motor, or my lathe motor, am I.missing something ?
I know some people attach motors, but to me you will lose the sensitive touch required. Even my lathe which is powered has a safety driver to be used locked in the headstock when using the jacot drum. If something goes wrong when it is motor driven it could be disasterous.
If it was simply for polishing I can understand a motor being used, but for burnishing (work hardening the surface) then think a bow would be the better way.
Just recieved my Jacot.
All good apart from the lantern on the smallest of pivots (1-12mm) is missing.have the opportunity to send back or get a partial refund.
Im assuming the smallest lantern will be required on balance staffs?
Edited by jnash
I agree with Geo. The reason I am looking to purchase a Jacot tool is to get more sensitivity which my lathe lacks. I have a foot pedal controller but things can still run away & out of control very quickly if not careful.
Agreed, for pivot polishing you have to feel what you are doing. A motor takes most of your control away.
However, when making a new staff I like to size the final pivot diameter on the Jacot tool and I have often wondered wether what it would turn out like using a motor driven Jacot like a Rollifit - check it out:
https://www.google.co.uk/search?q=rollifit&espv=2&biw=1815&bih=905&tbm=isch&tbo=u&source=univ&sa=X&ei=0J9kVPW2FI7varzCgoAD&ved=0CCMQsAQ
Personally I would send that back - it's next to useless.
Check this one out - I can't see the lanterns properly but there seems to be spares in the box.
http://www.ebay.de/itm/Tour-a-pivoter-Steiner-Jacot-tool-lathe-Zapfenrolliergerat-Rolliersthul-Rollifit-/151472992713?pt=FR_YO_Bijoux8horlogerie_HorlogesPendules&hash=item23447e71c9
Its being sent back as we speak, its come at a bad time as it seems my Cowells lathe is damaged. So the refund will go to the spindle being fixed now...
Wise decision :)
You have a great blog by the way. Some great info on there.
You can link it in our Blog section if you like - just click to Add a blog and choose to "Link external Blog"
Thanks, would love to spend more time on the hobby however work takes priority. I'll add the blog thanks
    • Hi All. I would appreciate some advice for a complete newbie on getting into watch servicing - nothing serious,  just as a fun project. I've got a thing for hand-wound watches and would like to bring an old watch (or two) back to life, so looking to learn to do a strip-clean-oil-assemble cycle.   I've toyed with this idea in the past (years ago) and picked up a couple candidates to learn on, but never found the time for them.  One is an old Ingersoll, swiss-made 17 jewels. It seems to wind and tick. Casing, dial, glass are in great shape, so looks like a good candidate to me for the first service. The other is a Benrus DR23. It winds and makes a few reluctant ticks, but then seems to stop. Casing looks like a complete gonner, and the dial is in pretty poor shape too. If the movement is not broken and just needs a service, I wonder if there's any possibility of getting a cheapo Chinese casing & dial to fit this movement in, or is it extremely unlikely to be the right size?   For a start, I want to strip & assemble a movement, perhaps a dozen times to build up the basic parts handling skills. I see that online advice is to buy a Chinese-made ST36 for this purpose. Can I just go at the Benrus or Ingersoll instead, or does it make more sense to get a cheap ST for this? Thank you.
    • Hi,  I have this vintage Navitimer 806 with a bezel that plays a little bit as shown in this video: https://imgur.com/a/2NjdiF0 How would you fix this? I don't see where a gasket would fit for instance. Also, it seems this issue happens sometimes with older Navitimers.  Thanks
    • This is a screenshot of a video of it running. Not the best quality, though.
    • Depends what sizes of watches you mostly service . If you were to say pocket watches then you might benefit by wholly replacing the 9010 for 9020. As a rough guide hp500 is twice the viscosity of 9020 which is twice the viscosity of 9010 at 20°c.  So hp500 would give you a more mid-range oil between thin 9010 and HP1300, but as it happens hp750 is more mid- range than hp500, but is that more or less useful when oiling a train of wheels. After the barrel arbor the jump down in pivot size is around half, then after the centre wheel maybe more than half until the escapement. And pivot size isn't especially a deciding factor, as the torque and speed of a pivot would be more relevant when thinking about which oil to choose. So 750 might only be useful on a centre wheel and nothing else, and 500 might be better than 1300 for oiling the centre wheel but still comprises the rest of the train, where 9020 would be ok for the train but too thin for the centre wheel, leaving only 1300 for the oiling of it. You see the problem we're having here. What can be ok for one thing is less ok for another in a different way, damping down power compared to oil spread.  Maybe mixing a drop from two opposite range viscosity synthetic oils will give you some approximate thickness of an in-between . You want a short answer now ?  I tnink I'd go with the 9020. Now be prepared for a whole host of different answers. Then to go with this, watch manufacturers change their minds about which oils to use more times than actresses change their knickers.
