Bergeon Cannon Pinion Remover
Seth
Good Afternoon,I hope you are all keeping safe and well during this tough time.I wonder if anyone can help me with a small problem I have.I have just purchased a new Bergeon Cannon Pinion Remover and it will not remove any cannon pinion's from wristwatch movements as when the lever is fully depressed the collet will not close enough to grip the pinion it just is too big for watch pinion's.It works on large pocket watch movements but not on wristwatch movements of various sizes as I have tried 5 different movements with all the same results.I enclose photos of the new tool as received from H Walsh I await any replies before I send this back for a full refund. Regards,Seth.
When I bought mine the information on CousinsUK clearly stated: "for small and large watches” and ”adapted to all calibres”. It was not, and Cousins changed the description (added: "Can lift cannon pinions diameter Ø1.00 to Ø1.80mm") and refunded the money. I record a video about it...
Hi to you all,just a quick update on this Bergeon Cannon Pinion Remover 4854, I emailed Bergeon to say how disappointed I was that this item will not remove pinions of 1.0mm and less and Bergeon have said that this 4854 Cannon Pinion Remover is for pocket watches!! They suggest that I use either a Presto type remover or Hand levers (hairspring collet type) and they have even enclosed their part numbers and PDF images of these items!!!! Regards to all and keep safe,Seth.
Good Morning to you all and I hope you are all keeping safe and well.Just a quick update on my Bergeon Cannon Pinion Remover,l decided to keep the tool and investigate if I could alter the collet size somehow.Well after disassembly of the tool and looking at the collet size I found out that with a small alteration of a Dremel collet using my Lorch lathe I think I might be on to a winning situation!! I will keep you posted on this.Regards to all and keep safe,Seth.
Cut a piece of thin aluminm foil, like 1.5mm by 3mm, warp it aroumd a screwdrive about the diameter of canon pinion, role as you would a cigarrete, you are making a tube of aluminum, place the tube on the CANON pinion, you have increased diameter of the canon pinion by the tube's thickness, the tool grabs the bigger diameter.
It works.
Good luck.
  • jdm changed the title to Bergeon Cannon Pinion Remover
    • I think we are about there, if there were still lots out there then the cost of a watch from 5 years ago would be around the same as it is now (allowing for inflation). Given that the price has gone up several times over we can only assume that supply cannot keep up with demand so we must be at or past peak supply, especially if the trend continues. I see even places like Australia, Ukraine and even South America are selling watches on eBay, picking over their stocks, mixed in with fakes and Frankenwatches etc.
    • I understand the demand bit, the generation below me 30ish are too technology engrossed to own a mechanical watch and they just dont like old stuff. I also consider myself at the getting on age of 57 to be a rare find of someone that likes old stuff, i did buy an almost 100 year old book yesterday titled " The New Modern Home " printed 1929.  Cost me a quid. What i was trying to work out is if we have reached a volume peak of watches being discovered hidden in the back of drawers.  Those watches that were hung onto until they entered the hands of the non sentimental generation.
    • Even for myself who only started getting into watch repair/servicing during COVID I have seen a huge jump in watch prices - we have a 404 channel on this forum. When I started you could relatively easily find a watch on eBay to restore and put onto the channel, however this is now almost impossible and the only feasible solution is to buy a job lot with an average price <4.04. Even watches sold for parts/spares are 3 or four times the price of only a few years ago. Why - Either Demand must have increased in order to push up the price, or supply is reduced. I think it is a little of both, I think that most watches in the UK/US may have been picked over, which agrees with most of what @Neverenoughwatches says so supply of all kinds of vintage watches, including tat is dwindling. As a double whammy I think that more people are wanting watches, either to work on, or as a way to differentiate themselves from the Apple Watch and FitBit crowd. The upshot is that half decent watches that require restoration are now $500 instead of $100 and cheaper watches (Seiko 5 etc) are now $50 instead of $10, and even Mumbai Specials and garbage are now pushing $50 each. When - how long will this last, I think that most of the people who are returning to mechanical watches are those that have previously experienced life without them and want to return to something with a bit of personality that doesn't buzz every 10 seconds on your wrist and tell you how many steps you have done today. i.e. the 30-40+ generation. My son who is 17 has several mechanical watches but only wears one on a special occasion and is obviously only aware of them at all in part due to my hobby. I asked him the other day how many of his friends wear a watch and he told me that some use a smart watch but most just use their phones. So as I see it, demand will start to fall once the sub-thirty crowd start becoming the majority and/or the older amongst us stop buying watches and switch our attention to mobility scooters and trying to remember our bank password. Price - I think this is here to stay, even if demand does start to drop as the older generation becomes to decrepit and stops buying and the younger generation isn't interested in buying, supply will become progressively less as time goes on as more vintage watches become lost or broken beyond repair. I think the prices will plateau at some point as an equilibrium is reached as reduced demand is balanced with reduced supply, i.e. less and less people buying less and less watches. Sorry for the long ramble!
    • Hi. Use a PVA based glue, gorilla glue it dries transparent then do as advised by Old Hippy, smoothe down using very fine  0000 wire wool and either French polish or beeswax for a finish.
    • Hello and welcome to the forum.    Enjoy
