Citizen 8945 circuit board repair
gkmaia
BTW Have you checked the board under the microscope for cracks? These little PCBs have a hard life, and may be subject to heavy impacts, so they may suffer from hairline fractures.
EDIT2: Also check the tracks round any holes that may be subject to rubbing from plastic or metal fasteners. As you can see these are pretty small and thin tracks, so it doesn't take much friction to wear through them. Its difficult to tell from the pictures, but there are a couple of places like the one I have circled that look a little suspect.
Edited by AndyHull
EDIT2: Also check the tracks round any holes that may be subject to rubbing from plastic or metal fasteners. As you can see these are pretty small anda thin tracks, so it doesn't take much friction to wear through them.
Yes I did under 150x mag. No cracks. All the hole vias have continuity.
Did you try putting it back in the movement and screw down everything. Some sneaky designs use the metal screws to power or ground another section of the board.
Also, watches with the "hacking" function have a switch that activates the circuit only when the crown is pushed in.
16 hours ago, gkmaia said:
Interesting as the positive is the chassis. Never seen that. There must be a reason, something to do with the charge of the human body as it is in contact with it permanently
I suspect the reason for a positive ground as I would call it is that the battery case is the positive.  it makes it easier to manufacture than the battery can go in and make contact with the metal somewhere you only need a insulated contact for the negative part.
one of things you should probably do is look at the service manual carefully and see if there's any reference to? Okay they do not expect you to run the circuits without being in the watch some quartz watches conceivably will have more than one ground screw as they call them. Or it's conceivable that there may be more than one connection for the power and/or ground.
typically in a quartz watch the quartz crystals should always be oscillating. Initially when their manufactured they need a time to stabilize and allowing the watch to run basically from the instant it's manufactured until it's given to the customer helps with that stabilization. This is why analog watches will often be in the setting position so it's not driving the stepping motor it saves power. But the quartz crystal as oscillating. Then I have a link below company that manufactures quartz crystals for timepieces.
https://www.microcrystal.com/en/products/khz-quartz-crystals/
i will check but from my first photo the red dots are the the positive rail and the tail dots are the negative. there is no jumper so they are probably all connected.
i building a little oscillator circuit for small capacitance and low frequency crystals. See if that helps getting better signals from these crystals.
A couple of cmos inverters from say a 74HC04 hex inverter or a CD40106 should be all you need to get a good clean square wave from one of those watch crystals.
There are a bunch of schematics on line for this.
You could go old school and use a CMOS 555 without the crystal or even a single transistor or two transistors (with or without the crystal) as an oscillator just for testing.
Just be careful to keep the signal level reasonably weak and commoned  to and  at or below the supply voltage of the board so you don't cook anything.
i am building one with a 4049. etching the pcb now.
Ok, so the results are not good. I got a nice signal out of the original crystal and the new crystal with my built 4049 oscillator. Tested the var cap and it is good. Tested all the other components as well. All traces have continuity the ones that did not are fixed. Still no pulse.
Just a steady 1.5v at the crystal input and 750mv at it's output. All voltages across the board are either 1.5v or 750mv.
My only conclusion is that either i fried the IC at some stage or the little bit of battery electrolyte was enough to.
Okay so here is my secret stash of circuit boards for these babies:
http://stsupplyonline.com/catalog/8943-citizen-circuit-p-21065.html
Don't mind the 8943 nomenclature. The part number is the same for the 8944 8945 or 8943 models. The difference is the LCD.
I will have a spare board that doesn't have a working buzzer if you wanted it.
Otherwise I would look on ebay for 279-332. It comes up on ebay from time to time. I've bought a replacement for 20$ from the UK recently.
List of parts here:
http://boley.de/en/caliber/watchmovements/citizen/2863
And trust me, your not the only one struggling.
I have 16-17 of these watches in my drawer. I only scavenged 2 working boards from them all. 3 LCD's were working, the rest cracked.
I frequently get them from eBay India for peanuts. Before COVID they were sending free international post, usually 15-25$ AUD for a broken one. Good signs are usually when they come with a flat battery and/or no battery acid.
These boards are super fragile, I have no idea why.
Edited by AlexeiJ1
I suspect they were the same boards, but was not sure. Reason being the all had the same features and same LCD labels. That was clever. Nice way to preserve the whole circuit and evolve the case.
I would be keen to get your PCB with a missing buzzer. I am obsessed with this little fella. ?
Where about you are?  I am in NZ.
1 hour ago, gkmaia said:
I would say the circuitry in this IC is so simple and so crude that it does not allow for any protection against shorts, etc...
just as a reminder this isn't your normal integrated circuit. The watch companies are manufacturing their own components now more than likely was manufactured in house very specific for what it's used for. Sealed up in a metal case they probably didn't expect that they get exposed all sorts a bad undesirable stuff.
Then there is the other little problem what was the life expectancy of this watch? things change considerably when you're designing a circuit to last for a very long time in very harsh environments versus having it sealed up in a metal case run by a watch battery and you only wanted to last for? What would happen if they made watches it lasted forever how many more new watches what they sell. They probably not deliberately designed to fail but they weren't made the last forever either.
then there's another problem the program do they use ROM or did they use programmable memory? Even some of the analog quartz watches use logic programming to regulate the frequency of the crystal they abandoned trimmer capacitors. What is the life of that memory? I did a quick look here's the first link I found notice they're suggesting 10 years?
https://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv021.cgi?read=237068
Fortunately Seiko didn't take the obsolescence/short life approach with their first true production quartz analogue movement, the 3803...
https://i.imgur.com/S7WZCgX.jpg
Or indeed with their mid 1970's 'work horse' movement, the 0903, which is virtually bomb proof, both electrically and mechanically....
https://i.imgur.com/HhPskYe.jpg
The "condensers" are about the only things you can suspect, and have a chance of actually changing. They are pretty important. The "boosting" ones probably generate the split supply for the LCD and possibly other parts of the circuit. They may also be used for a charge pump boost the voltage to drive the rotor.
The chip is CMOS, so it is possible that it may be susceptible to damage by static electricity, but possibly impact and moisture are more likely candidates to kill the silicon.
If you have a working external 32768 Hz  oscillator (exact frequency for testing is probably not critical), and can inject a signal in to Xin (you may need to disconnect the crystal first) you might have some luck.
Actually you might be able to just touch the X in input with one finger and inject a little random noise there the display may flicker in to random life. If so, the chip is probably OK.
Without a working oscillator, I doubt if you wont see anything on the display, because the boost circuits for the LCD almost certainly rely on it and therefore wont work.
Having a working board to compare with would also be a big help.
Edited by AndyHull
If you have a working external 32768hz  oscillator (exact frequency for testing is probably not critical), and can inject a signal in to Xin (you may need to disconnect the crystal first) you might have some luck.
Tested the condensers on a LCR meter and they are fine. I have built an oscillator and the original crystals work fine. definitely a problem with the iC.
If you have a hot air rework station, you could hit it with some heat to re-solder it. This assumes it is not wire bonded rather than soldered of course.
Yes got a PACE MBT station. But the board is just too delicate to heat it up i am afraid it will bulge and also too close to the crystal. Just did low temp iron, wick and lots of patience. Apart from the IC all the other components are discreet components and they all tested fine.
With the new boards that will arrive will be great to see it and I will also make some charts of the signals to share.
Had some experiments with glass bead blasting at low PSI. looks really nice.
Edited by gkmaia
I'm in Australia.
I'm just waiting on a parcel that has been 6 weeks from US to replace my dodgy board, then I'll message you.
I have a Seiko 7549 bezel that needs glass bead blasting, I'd love that frosted finish - anychance you can help?
9 minutes ago, AlexeiJ1 said:
I'm in Australia.
Sure I can help you, no cost as well. I will send you a private message. Just need to strip it all like I did and glue, dirt and grease should be all removed before otherwise the beads wont impact the metal.
On 10/9/2020 at 7:51 PM, gkmaia said:
Would you know if there is a website like the https://boley.de/ but with codes for the case parts? So I can find the number.
By measuring it seems 27.3mm x 2.1mm.
https://www.esslinger.com/watch-crystal-flat-round-mineral-glass-crystal-2-0-mm-thick/
I am just not a 100% sure I can trust my gauge
There is a case section on Boley.de.
I just typed in 087836 as the case number.
Check if that is correct:
https://boley.de/en/case-parts/citizen/7099.4-087836?q=087836&p=0&s=50&l=7
The crystal is a 54-L0303H
There is one here: https://www.sapphytimes.com/citizen_crystals.html but you have to email them and check stock.
Ebay don't have any.
I'd just fit a generic flat crystal. I usually order 1 size down, 1 size up, 1 size correct.
Watchmakers usually (break one, fit one, keep one).
I use cousinsUK for crystals. They have more sizes than esslinger. To be honest esslinger dont stock a whole lot of anything compared to cousinsUK.
You can't rely on one place for reference information.
I use Jules Borel, Boley, Cousins, Seiko PDF's (search caliber + pdf), citizen PDF's, forums, etc.
Sometimes CousinsUK will list the part number for a caliber such as 8943 that will then let you track it down even if out of stock. That's how I found my first replacement NOS 8944 circuit board and LCD.
    • I understand the demand bit, the generation below me 30ish are too technology engrossed to own a mechanical watch and they just dont like old stuff. I also consider myself at the getting on age of 57 to be a rare find of someone that likes old stuff, i did buy an almost 100 year old book yesterday titled " The New Modern Home " printed 1929.  Cost me a quid. What i was trying to work out is if we have reached a volume peak of watches being discovered hidden in the back of drawers.  Those watches that were hung onto until they entered the hands of the non sentimental generation.
    • Even for myself who only started getting into watch repair/servicing during COVID I have seen a huge jump in watch prices - we have a 404 channel on this forum. When I started you could relatively easily find a watch on eBay to restore and put onto the channel, however this is now almost impossible and the only feasible solution is to buy a job lot with an average price <4.04. Even watches sold for parts/spares are 3 or four times the price of only a few years ago. Why - Either Demand must have increased in order to push up the price, or supply is reduced. I think it is a little of both, I think that most watches in the UK/US may have been picked over, which agrees with most of what @Neverenoughwatches says so supply of all kinds of vintage watches, including tat is dwindling. As a double whammy I think that more people are wanting watches, either to work on, or as a way to differentiate themselves from the Apple Watch and FitBit crowd. The upshot is that half decent watches that require restoration are now $500 instead of $100 and cheaper watches (Seiko 5 etc) are now $50 instead of $10, and even Mumbai Specials and garbage are now pushing $50 each. When - how long will this last, I think that most of the people who are returning to mechanical watches are those that have previously experienced life without them and want to return to something with a bit of personality that doesn't buzz every 10 seconds on your wrist and tell you how many steps you have done today. i.e. the 30-40+ generation. My son who is 17 has several mechanical watches but only wears one on a special occasion and is obviously only aware of them at all in part due to my hobby. I asked him the other day how many of his friends wear a watch and he told me that some use a smart watch but most just use their phones. So as I see it, demand will start to fall once the sub-thirty crowd start becoming the majority and/or the older amongst us stop buying watches and switch our attention to mobility scooters and trying to remember our bank password. Price - I think this is here to stay, even if demand does start to drop as the older generation becomes to decrepit and stops buying and the younger generation isn't interested in buying, supply will become progressively less as time goes on as more vintage watches become lost or broken beyond repair. I think the prices will plateau at some point as an equilibrium is reached as reduced demand is balanced with reduced supply, i.e. less and less people buying less and less watches. Sorry for the long ramble!
    • Hi. Use a PVA based glue, gorilla glue it dries transparent then do as advised by Old Hippy, smoothe down using very fine  0000 wire wool and either French polish or beeswax for a finish.
    • Hello and welcome to the forum.    Enjoy
    • The problem with oil in particular 9010 is it likes to spread. This is why you're supposed to use epilam anywhere it's used to keep the oil in place. Then you want to splurge on money you could buy 941 it's actually an oil that existed before 9415. Then the problem with the grease yes it stays in place but if you have too much you lose amplitude. Then if you get really obsessed with this he would follow Omega's recommendation for escapement lubrication. One of the problems with internal documents of the watch companies is typically are never going to see Them.But a few of them out in the wild for instance at this link Below I searched for the keyword of working. In particular working instructions of the Omega watch company for which there is way more than This but this is all they have. So you want to download number 40 as were going to talk about that and also download Number 81. Plus anything else that looks interesting https://www.cousinsuk.com/document/search?SearchString=Working Then number 40 covers lubrication of the watch. Most interesting is lubrication of the lever escapement under three different conditions with Lubrifar Which you probably no longer have has been washed off without which is what you have and then a course with epilam. Notice how they go supers super minimalistic with the 9415 because if it's too heavy you lose amplitude. Then if you lose amplitude the group will be disappointed with you and the end of the world will come.
