Watch hands
gary17
Hey guys
I need watch hands any kind or sort to fit a watch the hole size (and yes i have checked it is 1.6, 0.8 and the seconds 0.2.Tried cousins and they omnly seem to do them up to 1.5 for hour hands.
So were would i look now for a set of hands for a watch which the hour hand hole needs to be 1.6?
cheers
gary
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
