Hi All,
I have managed to mess up the removal of the acrylic crystal from the stainless steel case., I now have a broken rim of the crystal (where it fractured from the front of the crystal) still stuck into the recessed groove around the circumference, between the outside and what looks like a tension ring but I think is not, looks part of the case to me. It really is wedged in tight and i fear that if I use metal tools then the case will be damaged. Any ideas how to get that out? Solvent? Burn it and pick out the remains with peg wood? Any other ideas? All help appreciated. Steve.
You have to remove the bezel before you remove the crystal.
The bezel actually clamps the crystal in place, if you try to push off the crystal with the bezel in place the result is what you now have.
Thanks Marc, you are right, just popped the bezel off. I have a new crystal so no worries there. Can I ask is there any reference that tells you if it's a bezel fitted or not as they are sometimes hard to see? Or is it something you have just picked up over the years? Steve.
So far I have managed to work it out on the Seiko's that I have worked on but I believe there is a case parts reference guide that has been shared on here before. I'm not sure whom by but I have a feeling that it may have been @jdm. (My apologies @jdm id I have got that wrong).
22 minutes ago, steve1811uk said:
I guess that to fit the new crystal you would put the crystal in place and then press on the bezel around that to lock in place?
Yup
interesting timing for me to see this question. Someone else was looking for a citizen watch guide I tracked it down on the Internet for them. While I was there I saw a reference to the Seiko guide found at the link below you want to download the casing section as it covers lots of different casing scenarios for Seiko.
https://www.thewatchsite.com/threads/seiko-watch-technical-guide-hires-color.1801/#post-8749
As mentioned the Seiko casing guide has been repeatedly uploaded to this forum already. All is needed is to enter "casing guide" with quotes in the search box top right, or here it is again  1982.03 Seiko Case Servicing Guide.pdf
There are also extracts of old case parts list, which one can also find with the same search.
Edited by jdm
I thought at one time we even had a library of PDFs? Bad as you're well aware the people asking questions almost never do a search and the people answering questions don't do a search. Sometimes when I'm searching for stuff it will point this discussion group then I will pointed out but usually if I'm doing a search or this case I was looking up something else for someone else who wasn't doing their homework either. But there should be a way of cataloging all the resources and a way for all of us to remember were supposed to look someplace first. One of the things I wonder about is for all the people who attached the PDFs to the discussion how much space is taken up by all these PDFs they keep getting attached over and over again?
The idea is brought up periodically but my opinion. as I wrote in other discussions is that if it has to be an official topic it would require maintenance care and time that Admin and Mods most likely don't have.
If any members volunteers for that all he has to do is to create a topic and attach the documents organized and renamed as he judges better, so searching will work. Then all the Mods have to do is pin and star the topic so to have some better visibility. That is the same as some in other forums.
    • I would repeat what @nickelsilver says, and even more. I have at leas 10 old thread plates and I have never seen one that will cut like a normal die. I don't know if they are completely worn or have never been sharp enough, but I find them completely useless. And, for the new Indian ones, I have heard only bad things. For sure, if one tries to cut more thread on a winding stem, this hole of the plate is ruined. Further more, I have bad experience with all watch size thread dies that I could buy from the available machine  tool shops here. They could not cut normal thread even on brass rod. The size was significantly smaller and the pitch is like it should be for the claimed size... The thread shape was bad too. I will explain how I do threads. I use lathe that can cut threads and thus I can prepare perfect taps. I use milling attachment instead cutter in the tool post and so I can cut thread even on hardened rod. But I prefer to harden the rod after thread cutting and temper it only to light color change as to have the maximum hardness. Then I make a tap out of it by grinding. I prepare my dies for screw thread cutting with the taps I have prepared as described. In watchmaking, dies exist and are often used that are not cutting, but rather forming the thread. They are like nuts and don't have cutting holes and edges. This kind of dies I prepare and use. You will need soft steel plate , drill a hole in it, then cut thread, then make chamfer on one side, repeat the thread, harden. You can temper just a little or leave untempered, depending of the steel You use. Using such die is with soft steel rod (or completely annealed). Good oil is to be generously applied. The rod has to be with smaller diam than the thread size (about 0.8 - 0.9 x ), the diam is better determined by tries. The rod elongates by the thread forming too. When I have to make screws from harder material like SS, I just cut them on the lathe. You screw needs hardening and tempering to be finished as real screw.
    • You could make a guide/jig. Cut a slot in a piece of metal approx the same thickness as the screw head, then drill a hole (screw head diameter) in that slot.
    • Tried a SR920W and its completely dead after 3 weeks 🤷‍♂️
    • Thanks so much for quick replies. I got some watch repair tools ordered, and will get back with pictures once I removed the back lid and get into it 🙂
    • Welcome to the WRT forum.
