WHAT S this????
gary17
Hi guys
Left this over night in white vinegar and it want come off. So far i have washed it 3 times in ultasonic  and used ,petrel,white spirits ammonia and it aint shifting.Its like the metal is dissolving.
Also a bridge i left in has come out all blotchy pink blotches if i did not need it i would laugh but jeez.
Any ideas ???
cheers
gary
I have not used vinegar before for cleaning watch movements but I think you have indeed dissolved some of the metal. I have recently done some photo etching (failing to etch some gears) and I recognise the description of having pink blotches on brass (I assume the balance is brass).
Unfortunately the only way I found to remove the discolouration was to remove it mechanically with abrasives. I expect that the parts have probably corroded quite considerably after being left in vinegar and are unlikely to be usable. It probably wouldn't hurt to try cleaning them with some fine wet and dry but I wouldn't get your hopes up.
I probably agree with Nucejoe.
I would say what you are looking at is called Pit corrosion, as you cleaned a corroded part with vinegar it of course took away the rust and left the part full with pits and oxide residues. So as the most here already said it is and was an write off from the begining .
Only use vinegar or other acids to take away surface rust. Use a glass fiber pen to wipe off the residue and  to see how much is gone. Afterwards you always have to polish the part up a bit.
I see it is the Landeron 48 bridge with two holes by the big one, almost threw in one for a Landeron 248 instead.
But here we go this should be a better part to practice on, I throw it in the kit for you.
    • Hi to Blackminou29–am a collector/ caretaker—good luck to you following your repair course—with hindsight I wish I’d pursued a career in both watchmaker/ jeweler fields—good luck with whatever career passion you engage.   Thank you Watchweasol for posting the amazing TZIllustratedGlossary! Best wishes, Mike
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
