Not long ago, somebody on here kindly provided me with a complete parts list pdf for the Harley Ronda 726 chronograph.
I thought I had got it safely saved but, like a click spring, it has vanished into thin air!
Any chance of another pdf, please?
Indeed, that is the very one............hooray!
"Thank you" for your prompt reply and my apology to Watchweasol for
not remembering his 'name'.
Regards.
Len.
Hi  Joe  Under the heading resources there could be put a heading to enable us to either drio in the link,  or the PDF's as we pick them up,  Maybe one for the future. I have a fair collection on my machines and would willingly put them up.  Google drive  I belive is a source on the net.
Hi Weasol, I remember my words in my first PM to you;
" What is easy for you,  might seem impossible to someone else"
Ease of access and simplicity to understand are keys to education for all.
Perhaps you find some way, a lesson and simple instructions, flow chart ....on how to access the files, is a key, however, the universality of the key may start with the title flashing off-on before the seeker eyes.
One might have the potential to become a master horologist but not understand a word of computer stuff.
Best wishes Joe
49 minutes ago, Tudor said:
This is a great idea. I am willing to contribute as well!
Hi, Friends share, well almost, thanks to old hippy this forum is the friendliest, therefor the richest in educating.
My thanks to everyone that contributed to this request.
I have safely downloaded the pdf onto disc and flash drive.
Again, "thanks."
1 hour ago, Watchtime said:
@Nucejoe @watchweasol Good point, maybe we can ask Mark what we can do, some kind of library
It has been discussed before and the idea is not walking, for one side it requires maintenance work, for the other usually this type of documents can be found with a simple Internet search.
Quote
In case there is a possibility to share  here on WRT, I am happy to upload my collection of a few hundred service sheets....
Nothing prevents you from attaching them to a new topic with as many postings are needed. Then you can ask moderators to pin or star the topic.
Edited by jdm
    • I have only made screws down to M1 & 14BA & I had trouble getting the slot in the centre of the head so I made a jig to help me be more accurate when cutting the slot, here is my video.
    • I would repeat what @nickelsilver says, and even more. I have at leas 10 old thread plates and I have never seen one that will cut like a normal die. I don't know if they are completely worn or have never been sharp enough, but I find them completely useless. And, for the new Indian ones, I have heard only bad things. For sure, if one tries to cut more thread on a winding stem, this hole of the plate is ruined. Further more, I have bad experience with all watch size thread dies that I could buy from the available machine  tool shops here. They could not cut normal thread even on brass rod. The size was significantly smaller and the pitch is like it should be for the claimed size... The thread shape was bad too. I will explain how I do threads. I use lathe that can cut threads and thus I can prepare perfect taps. I use milling attachment instead cutter in the tool post and so I can cut thread even on hardened rod. But I prefer to harden the rod after thread cutting and temper it only to light color change as to have the maximum hardness. Then I make a tap out of it by grinding. I prepare my dies for screw thread cutting with the taps I have prepared as described. In watchmaking, dies exist and are often used that are not cutting, but rather forming the thread. They are like nuts and don't have cutting holes and edges. This kind of dies I prepare and use. You will need soft steel plate , drill a hole in it, then cut thread, then make chamfer on one side, repeat the thread, harden. You can temper just a little or leave untempered, depending of the steel You use. Using such die is with soft steel rod (or completely annealed). Good oil is to be generously applied. The rod has to be with smaller diam than the thread size (about 0.8 - 0.9 x ), the diam is better determined by tries. The rod elongates by the thread forming too. When I have to make screws from harder material like SS, I just cut them on the lathe. You screw needs hardening and tempering to be finished as real screw.
    • You could make a guide/jig. Cut a slot in a piece of metal approx the same thickness as the screw head, then drill a hole (screw head diameter) in that slot.
    • Tried a SR920W and its completely dead after 3 weeks 🤷‍♂️
    • Thanks so much for quick replies. I got some watch repair tools ordered, and will get back with pictures once I removed the back lid and get into it 🙂
