I just got off the phone with a Bulova representative. He told me they've officially closed Bulova's New York office permanently due to Covid-19. That's a lot of history that just got shut down... Hadn't seen that in any news/blogs/etc., so thought I'd share.
Sad news. The master tool and die maker that taught me the right way to machine things worked there. I should send him a note and let him know...
Thanks for sharing!
11 hours ago, Acidstain said:
Bulova is moving to Torrance, CA. Right where citizen UsA headquarters is.
So they are joining the parent company.
FYI, we have a section on this forum where it's considered polite for new members to introduce themselves.
The reason I called Bulova in the first place was because I needed a warranty repair on the one and only new watch I've ever owned. It was a silly and obvious repair (four case screws came loose), but being the sort of person that takes up this sort of hobby, it's rare I own things with warranties, and I wanted to preserve it.
Part of Bulova's moving means that inventory is moving, and they're not set up yet. As a result, any Bulova specific anything is delayed out many months right now. A bit crazy. My watch was from back when Bulova got a new CEO ca. 2014 and he tried to move the brand back up market with some higher end pieces with ETA movements. I got it NOS 6 years after it was produced, and combined with Citizen not stocking ETA stuff and all the rest, I didn't have to wait the multiple months.
Unfortunately, it seems they don't actually service watches any more. They replace movements (which they don't stock, and can't get in my case), or they replace the watch. Apparently, they won't even regulate a movement anymore! Since my watch didn't have a Citizen group movement to begin with AND is 6 years out of production, my warranty turned out to be worthless unless I wanted to trade my watch in for one of equal or lesser value (which, in Bulova's current lineup, is all but two watches). Kind of a bummer. I looked long and hard to find that specific model. But I guess it frees me up to do all the warranty voiding things I would do otherwise, so... Cool.
Edited by spectre6000
?  Well, thanks for the heads-up.  I also own a brand new Bulova, given as an anniversary gift from my workplace.  I now plan to just shrug my shoulders and work on it myself.
I hear of so many watchmakers that operate in similar fashion these days.
A unfortunate problem of when a watch company gets absorbed by another company what happens to it. Initially like in this case they let Bulova run Independents but at some point in time it basically is only a name.
https://en.wikipedia.org/wiki/Bulova
    • Sounds like you've either got a short somewhere or excess friction that's draining the battery. Are both insulators still under the battery.
    • I have only made screws down to M1 & 14BA & I had trouble getting the slot in the centre of the head so I made a jig to help me be more accurate when cutting the slot, here is my video.
    • I would repeat what @nickelsilver says, and even more. I have at leas 10 old thread plates and I have never seen one that will cut like a normal die. I don't know if they are completely worn or have never been sharp enough, but I find them completely useless. And, for the new Indian ones, I have heard only bad things. For sure, if one tries to cut more thread on a winding stem, this hole of the plate is ruined. Further more, I have bad experience with all watch size thread dies that I could buy from the available machine  tool shops here. They could not cut normal thread even on brass rod. The size was significantly smaller and the pitch is like it should be for the claimed size... The thread shape was bad too. I will explain how I do threads. I use lathe that can cut threads and thus I can prepare perfect taps. I use milling attachment instead cutter in the tool post and so I can cut thread even on hardened rod. But I prefer to harden the rod after thread cutting and temper it only to light color change as to have the maximum hardness. Then I make a tap out of it by grinding. I prepare my dies for screw thread cutting with the taps I have prepared as described. In watchmaking, dies exist and are often used that are not cutting, but rather forming the thread. They are like nuts and don't have cutting holes and edges. This kind of dies I prepare and use. You will need soft steel plate , drill a hole in it, then cut thread, then make chamfer on one side, repeat the thread, harden. You can temper just a little or leave untempered, depending of the steel You use. Using such die is with soft steel rod (or completely annealed). Good oil is to be generously applied. The rod has to be with smaller diam than the thread size (about 0.8 - 0.9 x ), the diam is better determined by tries. The rod elongates by the thread forming too. When I have to make screws from harder material like SS, I just cut them on the lathe. You screw needs hardening and tempering to be finished as real screw.
    • You could make a guide/jig. Cut a slot in a piece of metal approx the same thickness as the screw head, then drill a hole (screw head diameter) in that slot.
    • Tried a SR920W and its completely dead after 3 weeks 🤷‍♂️
