Help removing movement from case
Hi everyone,
I'm trying to remove a valjoux 7750 from a Maurice Lacroix MP 6348 and I believe it is accessed from the front of the watch.
The crown and stem are removed and the two retaining screws are out, the dial and movement rotate freely but the movement won't release.
One of the sub dial hands has come away so I'm trying to take the hand out to avoid dial damage.
Does anyone have experience with this or these watches? I know there are bezel removal tools from bergeon etc but wasn't sure if those worked on stationary bezels.
Thanks to anyone that has some insight.
So far as I know this is the type of bezel remover you need to use for that style bezel. I bought one of these to help remove rotating dive bezels (on the advice of someone) and my experience is it is poorly suited to that task, but I think it would be perfect for what you're trying to do.
I've never needed to remove a friction bezel and these pictures are from the Internet.
48 minutes ago, vinn3 said:
have you removed the bezel?  put the stem back in until the bezel is off,   if it did not go in,  you have a "dial off situation".  good luck.  vin
Haven't removed the bezel yet. The keyless works needs rebuilding as the stem won't go back in
This is the tool I thought it would need, will try and get hold of one, thank you.
Hi  The device BrianB pictured will work well enough on a stationary dial as well as the rotary version, C case knife under the bezel lip and twist will bring it off. Hold the watch in a cloth and be careful not to mark the case side. There is sometimes a small notch for the knife so have a good look round the case sides.
I've had a look through a loupe and can't see any notches. I can't work out if the bezel removes from the lip or below that where there appears to be a seam
Just tried with a case knife with a fair amount of force and there was zero give at all!
Removing bezels can be problematic if you encounter a tight one. I do own the tool suggested but it can be too brutal and if not careful ( From bitter experience) it can distort the bezel. I use a vintage butter knife. It is sharp enough to get under the bezel but being flexible you can feel the tension being applied.
However the movement should be removable without removing the bezel. Looking at the pics I would say it is a friction fitted case back
The case back is screw down, I've removed this, taken the stem out and undone the two screws that hold the movement to movement ring. The movement ring doesn't budge, it's part of the actual case, I didn't think the movement and dial could come out if the movement ring is fixed?
Ok agree looking at the pics it does not have a traditional bezel. However the movement and dial should come out unless the dial has a lip. If so then the surrounding bezel will have to be removed, Cristal removed then the movement will come out from the front.
10 hours ago, watchweasol said:
Hi   Just a thought  the bezel could be screwed on, try using a sticky ball to unscrew it.
You're an absolute genius! Never would I have thought it would be a screw down bezel. Put it upside down in a movement holder that grabbed exactly where the bezel inverts and viola! Thank you so much
That’s how the original Oyster case worked.  Those “flashy” knurled bezels, they continue to use, used to fit a tool to unscrew the bezel just like the case back.
This is the first I’ve heard of it outside Rolex.
I think Panerai continued that case assembly method after Rolex stopped using it. No idea if the modern ones still do. I believe they were using Rolex pocket watch movements as well.
Ive never handled a Panerai, so I can’t say more about dealing with them.
    • Depends where you are with repairing, watches like you have just mentioned  the Smiths, Ingersolls, Services are often pin pallet watches with low jewel counts, not impossible to fix but often quite difficult due to having more wear than a fairly standard 15 or 17 jewel movement. Saying that you may be lucky and pick one up that was never used much. As an example i spent a few weeks on and off getting the most i could from an old Smiths Empire, that did actually finish at within 2 minutes per week that could be improved further now i know it is fairly precise but not quite accurate . Sekondas are good practice pieces at around a tenner, though some folk call them rough but robust.
    • Hello people , this is maybe a question that the moderators can answer.  Can seperate posts be unmerged from each other. Sometimes posts are missed by others because of a continuation of them . Even when answering seperate people the posts are grouped together as one. Maybe it saves message board space ?
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ? Stearic acid experiment underway,  its started to melt at around  65° C. The idea is to find a large cap jewel to suspend over the vapour release.
    • That's the size of my grandfather's Ernest Borel watch. Definitely not a lady's watch! 👍
