Re-casing my Wolbrook:
It is an 11 1/2 ligne Clinton "Wolbrook" from maybe early-'70s. As movements go, it's monetary value is doubtless pretty slight.  But it was my first wristwatch - from late-grade school until middle school. In ninth grade I took a fall at the bus stop, so hard a fall that it tore a divot in my knee, and cracked the watch case clean through just on the inner side of one of the lugs. Figuring the case was done for, I discarded it, but I saved the movement, face, back, and crystal (which I *can* part with, being scratched). It has been cleaned and oiled and runs well and accurately.
Can anyone recommend a good 11 1/2 ligne gold case for it? Gold-on-stainless maybe? If it also comes with an exhibition back, that would be awesome but not required. I don't wear wristwatches that often, but this one I would love to be wearing once again.
1 hour ago, yankeedog said:
Dial  diameter? I may have something  laying  about In stainless..but.not an exhibition  back.
I measured it at 25.9 mm.  If you happen to have a classic case style I like, let me know how much you want for it and I can reimburse.  I'd like to try to find just a simple gold case like it used to have, a basic but dressy case. SK didn't quite have what I wanted, and the ones I saw on Ebay and Etsy didn't mention dial diameter so I didn't know what I would get.  The few others I found that could accommodate my dial were all silver-toned stainless.  (I feel I am being hard to please here, but It would feel more comforting to have the Wolbrook in a gold case.)
I have a gold 11.5" case with a stainless back. It fits an AS 1526. Dial aperture is ~26.9mm. A few scratches/nicks. PM me if you are interested, and I'll take photos and what have you.
Edited by spectre6000
It's alright. A watch is a very personal  thing. I may have something that  will work. I have a watch with that movement  with about that dial size. I will see if I have a gold tone  case that fits  it. If I do I must forewarn you,it will be serviceable  but not pristine.
It looks like your movement  is an HB 115. I have one in a Landau watch with 17 jewels.it runs nicely.  When I get a chance,probably this weekend  I will pop it out of the case  and see what it fits. Is that  dial flat ?  Or dished?Can you show  me a picture of it in profile?
Thank you for the offers, Spectre6000 and Yankeedog. I will be posting better pics of the dial (it does happen to be slightly dished upward - the edges curve down - it had a high dome crystal) and more complete measurements and dimensions,...and this old-school analog human-being will figure out how to PM someone in this forum.  Can't be too hard.
Edited by KarlvonKoln
Clarity
HB115
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&HB_115
HB120
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&HB_120
It definitely looks to be related to the HB115, but more likely a less "super-shock-resist" variation of the HB120. Ranfft doesn't have such a caliber listed, but it stands to reason it would exist.
I took a couple pictures to show the slight upward dish on the dial.
And it just occurred to me: I need to find a pair of gold hands.  Back to the internet...
Made an addition
This is what I could scare  up. It's a well used chrome/ gold colored  case. I have verified the case and ring  will fit an HB115 movement  with 25.9 mm dial similar to yours. The back is not original  to the case but screws down tightly and has a gasket  and nothing rattles. There is of course  a no sale rule and this is just stuff from my junk box. But it should  yield  you a functional  watch.
Edited by yankeedog
Thank you.  In the interest of disclosure, I think I may have found something already.  But may I keep this in mind if the other won't work out?  That case also matches with what I had in mind.
I haven't posted to this thread in a while so I don't know who will see it, but my little old Wolbrook is recased again!  Many thanks to Yankeedog here, who sent me one of his old cases.  I am wearing it now for old times sake.  As I mentioned, I wore this in grade school.  I remember checking it to see how much longer I could spend in the bookmobile, when my bus would come, when my crossguard duty was over, timed tests, so many memories.  Yeah, it's a little Clinton Co. cheapo, but it is a small vessel full to the brim with my history.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the hole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
