Sorna 5 Crown pin lever - Help !
Hi all, I have just introduced myself “over there” and was hoping I’d find someone here that can sort this for me.
I have coveted this watch for ages and loved wearing it but today ..... well, I hope someone can help.
I know that some of these Sorna Pin Lever movements are regarded as junk but this one of my favourite watches in my collection. While setting the time today, the crown/stem came out and after some investigation, it appears the “lever” that allows selection between winding and setting has snapped. Excuse my layman’s terms. Please say this is a relatively generic piece and a qualified watchmaker could get this sorted. Chrono still works fine and seconds run. Movement is hacked and as such, does not advance.
Really want this fixed.
Thanks
garp
Final photo shows the piece that broke - taken from another post on here.
Looking at the movement I would say apart from the fault it needs a clean & service. The actual part that is broken however is the issue. Finding one is going to be difficult. I suggest looking on sites such as eBay to find a donor movement.
I agree on all points. I’m hoping to find someone on this forum who may have a donor movement or better still, be able to repair it for me.
31 minutes ago, HSL said:
That seems to bee an EB 8420 movement, not very common but if you look at the ebay there use to be one or two sometimes.
Oh .... I’m looking. Everywhere! I don’t want the donor to be one from my collection.
Took a quick look at the bay..
Movement, seems to be missing the fourt wheel.
https://www.ebay.com/itm/Eb8420-Watch-Movement-Spares-Or-Repair/303627042847?hash=item46b195001f:g:3HgAAOSwS41fEvwF
Just parts
https://www.ebay.com/sch/173696/i.html?_from=R40&_nkw=EB+8420&LH_TitleDesc=0&_pgn=1
3 hours ago, HSL said:
....been searching all day. Somehow that one got past me. Thanks.
worry is without crown there perhaps it’s missing but fir a few quid...,
8 hours ago, watchweasol said:
Hi Looks like the setting lever has broken off .   You will find the part and number on the attached tech sheet. Try Ebay  or obsoletewatchandclockparts.com,  Welwynwatchparts.co.uk as both are a source of used spares.  Good luck.
Watchweasol- so I have managed to find a NOS part. 443/1 as requested. Like your .pdf it references eb8423 movement- apparently my movement is eb8420 - it look exactly the same so hopefully it’ll work. Is there any difference ?  Failing this, there is a eb8420 broken movement on eBay which I’m watching.
thanks
8 minutes ago, Garp said:
It is in their stock listing ..... sadly, listed as obsolete. Thanks nonetheless. I think I have a lead on one.
They have the  8429 one in stock, which appears to be very similar, if not the same......
    • One-dip or naphtha should be safe, but are you sure it isn't magnetized?  I would also check that.  Although, if that balance is from an Elgin 760 0r 761, I would think it would have a hairspring of non-magnetic alloy.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
    • No thats straight out of the watch as i found it the balance wheel is almost as bad. I've never seen so much material removed.
