Any Citizen experts around?
Hi, Just bought this Citizen watch, the first Citizen I have ever owned. Just wondered if anyone knew anything about it. Never seen anything quite like the dial, looks like hammerite paint. Code on the back shows 7220. Watch is running at 21600 bph. Not opened it yet, what might I find inside?23b6154914b012a202bf6e4815eb6c15.jpg6a9d1a3870ebd26e607334cb40bfb67b.jpg
Sent from my Moto G (5) Plus using Tapatalk
20 minutes ago, steve1811uk said:
Fantastic, any idea how to source a replacement acrylic crystal as the original is too far gone?
There is no secret place for parts, we all search the Internet just like anyone can.
You can also measure and get a generic plastic or mineral glass crystal.
Edited by jdm
I mean, for Seiko I would search the case code on Jules Borel and find out the part code for the crystal. Is there a similar way to that for Citizen parts?
Not that I am aware, Citizen has always been behind Seiko in terms of post-sales support. BTW the same parts search is also possible on Cousins UK, Boley.de, and Seiko Australia.
From what I see you acrilic crystal is still repairable to a good extent, personally I would look for a solid mineral glass replacement.
Thewatchsite.com specialize in Japanese watches only, you can try searching or asking there.
Edited by jdm
Glass looks you might get by with a polish.
Forgot to mention that escape has shock protection too with real little lyre springs, be carful with them.
Winder module is incorporated in gear bridge,  don't know what oil is to be used.
A datasheet be nice.
Good luck
Hi  unable to get a de code of the case numbers when you open up the watch can you post the calibre number please.  there are numbers on the dial under the no 6 marker can you also post theseif legible then we may be able to get a tech sheet,  Thanks.
Thanks, I will open it up tomorrow and also post the numbers off the dial.
7220 is a nice movement.. it has a full bridge but at least the automatic bits have their own bridge. The click is a bit difficult to spot. Once you remove the automatic reversing gears you will spot the tail. If you still cant spot it wind it a bit and you will see the click move.
Later 8220 had everything under a single bridge which is more fun...
Anilv
I found this great resource for finding case part numbers.
Nos Crystal part numbers, gasket part numbers. Etc.
https://www.boley.de/en/case-parts/citizen
Not sure if it will be a big help because it’s not comprehensive.
Here’s a link to info on movements too.
https://www.vintagewatchesspare.com/watch-parts-branded/citizen-calibre-movement-and-spares/
In the mean time check out this serial number decoder.
Might help.
Citizen
Citizen serial number decoder. Date a Citizen watch by serial number and case markings
If you can take a picture of the tiny writing just below 6 o-clock it will usually have the movement number.
Might help.
Citizen
Hi, please see some pics attached. Dial says JAPAN 6501 - 653316 KA. Not what we were expecting I think. Pretty sure the calibre reads 6501.de83a7d5cd29ec1acec283b80c27e90e.jpg390ea7bc388a0aa0a1a7ed6be3c45a7b.jpg52982df5f993638b22d64a4c50b15f12.jpg5a36f2404831bf9c73f4a468fe8e8b0c.jpg
I think this rotor has been scavenged off of 6001 which came in 17 & 21  jewels versons. Several parts are interchangable between the two. Not the caliber I spoke of.
This Calib 6501 is 21 jeweler.
I will be sure to count them when I strip it down. I think you could be right about the rotor.
$24.75 + $13 int.l sh. + UK VAT and fees.
Watch is worth, perhaps, the same. Worth to purchase, when generic or polishing are valid alternatives?
Probably not. In fact I found an equivalent on Cousins for approx £8. Original glass is too far gone has cracks on the edge and a big deep chip out of the front where it says Automatic.057ae9914a3fd9f5cadc5ab36f94a64f.jpg
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
