By nickelsilver · Posted
I agree on the pivot- and I would check very carefully the cap jewel (and hole jewel), it likely has wear as well. -
It's hard to tell from the pic (and I know it's very hard to get a good pic) but I agree with Frank. The pivot looks (possibly) worn at the end. Look at the line of light reflection
Picture is too blurred, but this (lower) pivot does not look good. Frank
hello will this watch case be sufficient, i was thinking i could use this watches case as a replacement. will this idea of mine of finding donor watches work? if anyone could please link some it will be really helpful https://www.ebay.com/itm/133161104092
I recently had exactly the same problem on an ETA 2773. Cousins don't stock the reversers any more, but I found another cleaning cycle made things much better. I had been using my own mix of lubricant - 9010/naphtha, but now I've switched to Lubetta I'm getting more consistent results
