French travelling alarm clock balance
Mugsey
Hi all have just joined this forum wondered if any one could help me in locating a balance for this little french travelling alarm tree is no name on the movement so would appreciate any info. I have seen several of a similar nature but don’t no I should be asking for the diameter of the balance is approx 14 mm which looks more like a watch balance
thanks
Hi Can you please post some pictures of the workings of the clock and the balance in particular.   It is most likely a platform escapement and if so is replaceable as a unit if the spares are available.  But we need to see the movement  before deciding on a courese of action.   Thank you
Hi  Thank you for the pictures,  Its not a platform escapement in the traditional sense,  I doubt very much if spares are readily available .   If the balance staff is broken it is most likely to make one  or have one made.  or alternativly try and source an donor unit to cannibalise the parts.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
