Hi from Marseille
Ozedfr
Hello,
like my father I have always loved watches and especially mechanical watches. I am 52 years old and I do not despair of knowing how to repair a watch one day. As you can see the English language is not my strong point and yet Mark's videos are very accessible and exceptional (merci beaucoup Mark!!!). Even at my age, mastery of the English language remains an obstacle for me and I hope to progress using the videos in original version and possible discussions.
I don't have a watch from prestigious brands, I have a few watches from the 60s / 70s / 80s and I have a Yema Superman that was offered to me for my Baccalaureat for which I want to do the restoration myself and hope find a bezel lock lost by my brother some years ago.
Thank you for your understanding and your help in advance.
Ozedfr
alias Gilles
