Omega 565 won't tick
Hello everyone. This is my second post here on the forum, so I just wanted to start by saying thankyou to all contributors and great advice available on here. Much of what I've read here has helped me through the intricate process of watch repair.
And so I digress. I have an Omega 565 Movement that stopped ticking a while back. Upon removing the case back, I found it was extremely dirty (see photo) I stripped/cleaned/lubricated the movement in the hope that a service would breathe some life into it. To no avail.
My first thought was that the mainspring wasn't producing enough power, or that there was a blockage in the gears somewhere. However, with the balance removed and the mainspring wound, the pallet fork will 'flick' from side to side when gently agitated by a screw driver. Thus I'm assuming that torque is being transfered through the train to the escape wheel.
So naturally I suspected the balance was at fault, but the hairsping is in excellent condition and it appears visibly fine. When fitted to the watch, the balance wheel moves freely on its bearings.
If someone could point me towards any other areas to check I'd be very appreciative. Upon tear down and reassembly, all the jewels and gears appeared to be in good condition. As did the pallet jewels.
Thanks a lot.
David
Thanks a lot.
David
Afternoon David!
Have you checked the roller jewel isn’t broken?
Hi   So it has been dismantled,cleaned and oiled and still not working although the power reaches the fork? .  After checking indeed that the roller and impulse pin are intact and not loose I should check that the impulse pin lies central in the fork/pallet and central in the banking pins with the power taken off the watch and the movement at rest. This will tell us if the watch is in beat or close, if it hangs to the left or right the watch is out of beat and will not run untill put in beat.  If it lies central and the roller is good and the impulse jewel is good  then remove the balance and the pallet/fork and re check the train power. Did you remove the mainspring for cleaning and oiling? and does the train rum free when the spring is given a turn. all points worth checking.     attached is the service sheet for the 565.         cheers
377_Omega 565 NewLR (3).pdf
as you are new to the group is this your first watch your servicing?
I seem to be having eyesight problems and I'm not seeing the photo?
One of the problems in watch repair is assuming that cleaning will fix the problem. So if the watch stopped in the past and wouldn't run at all and cleaning properly in all the proper lubrication etc. hasn't fix the problem then whatever the original problem is probably still there.
Then when you reassembled and discovered the problem is the automatic assembly currently on the calendar etc.
Thanks for the helpful tips. Think I may have found the culprit. I am a novice so go easy on me.
But first...
Dirty movement IMG_20200608_135826.thumb.jpg.427048972d8880783d8bbd69d2f67b57.jpg
After cleaning (minus balance and fork)
Balance in apparently good condition. Impulse jewel looks good to me unless anyone thinks otherwise? Hairsping also seems in fine condition.
Pallet fork. Fork horn and guard pin look good as do the stones (again please correct if I'm wrong)
IMG_20200625_181506.thumb.jpg.5ed4f00e400684ce61068a06979f7e61.jpgIMG_20200625_181244.thumb.jpg.3ea923cdd4d86bef81e68a29a8b67a42.jpg
Decided to. Remove the fork and balance to see if the power was moving freely through the gears. Then noticed this!
So upon winding the mainspring lightly, the train was binding due to the (third wheel??) being bent.
So my plan is to replace the third wheel, check that the impulse jewel is centred and then try again.
Hoping this will cure it.
As an aside, am I right in thinking this is a 'beat adjuster' allowing you to move the relative position of the impulse jewel?
Thanks as ever for your understanding and input.
I am aware that I am learning on a fairly intricate movement, but loving the process nonetheless.
Hi   The third wheel is out of true causing bad inlerlocking of the teeth with its neighbours, If you able to remove and straighten the wheel (re poise) and re fit or alternativly replace the wheel I will be a worker,   If you are in the UK  Cousins UK watch parts is the place to look of Stateside  Esslingers  Jules Borel  Otto Frei all material houses.  Yes that is the beat adjuster the rate is by adjusting the screw  on the lyre spring adjuster.           If we sound a bit short at times we are only trying to  Point you in the right direction diagnose the fault and  recommend procedures for you to do to help things along. You have done well enough to get this far .   So well done:thumbsu:
Shoud you decide to straigthen the wheel, keep in mind to do the straigthening without any force imparted to its arbour or teeth of the gear.
I often do the straigthening when its inside the movement, easier to take the wheel out for straigthening in which case hold the wheel itself and not its arbour, as you straigthen. Keep assessing where is be raised or lowered as you go.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ?
    • That's the size of my grandfather's Ernest Borel watch. Definitely not a lady's watch! 👍
    • Thanks H It does have a big crown for the watch , it could be considered a ladies watch these days i guess, it measures 33mm case 36mm with that large crown 18mm lug space. A tad small for a guy of today, but still very wearable. The photo was deceptive so here it is adorning my 7 1/4 " wrist. It need some love to make it run better. The hair coils are touching so running a bit fast at the moment,  not caused by magnetism, and maybe just a clean and a service. The dtal is in fantastic shape.
    • That's one beautiful timepiece! Love the big crown in proportion to the case. Perhaps a ladies' watch, but I don't think so. I have a "modern Ingersoll" watch, but it has nothing to do with the original brand (Miyota 9015 movement). Interesting synonym for synthetic oils! 😆 There is, of course, a limit to how large a volume of oil epilame can bind and hold in place. If the oleophobic effect is too strong then it can become a problem. I'm not sure where I heard or read it, but as I understand it, the active ingredient in a bottle of epilame is extremely small and more than 99% of the contents of the bottle is just a transfer agent. If the active ingredient becomes too concentrated, which it can become over time, or if the product is of poor quality, the oleophobic effect is amplified. This in turn causes the applied oil to look like a gummed-up ball on the surface of the treated part. If that happens, we know that the active ingredient has become too concentrated. What we want is for the oil to bind but not to the point where it is formed into an excessively round ball on the surface. The highlighted text in the patent that you refer to describes well the problem that can arise with too high a concentration of the active ingredient. However, I would be extremely surprised if the entire amount of oil leaves the treated surface as water on wax would. At present, I am convinced that the analogy between wax and water on the one hand and epilame and oil on the other is incorrect. Epilame is described as binding and that is also my absolute experience. Epilame probably has some repelling effect but that is not its main purpose and that is not how epilame is designed and works. The method of abrading the epilame treatment from the section of the pallet stones coming in contact with the escape wheel teeth seems after even more research to be well established, but if it actually works, if so how and why is beyond what I can currently understand. Perhaps it is just to do and trust that it is based on well-established experience. I am, after all, inclined to think so.
    • Sorry to jump in here, but I didn't want to start a new thread when there's already one regarding the second hand watch market. Can anyone tell me what I should be looking at when buying watches from eBay? I see loads on there for quite cheap, but after reading this thread I'm guessing they're all garbage and not worth the time? I recently bought an old Elco watch for 99p, just to practice on. I'm also really fond of the look of Services watches and Smiths Empire watches. I keep seeing them listed for around 5 or 6 pounds. Are they not worth the time buying? I'm not looking to sell watches to make a profit. I just want to buy watches I like the look of and wear them, but I also don't want to buy things that are going to be impossible to find parts for, or that have already been abused by someone else and broken beyond repair. Any tips?
