Hello Everyone,
I'm looking forward to getting acquainted with you all as I dive into watchmaking and collecting again after a little hiatus of a couple of years. For those who saw my introduction post, I am a keen russian watch collector and I'm tinkering with watchmaking after having done a couple of online courses several years ago.
I have in my collection a Poljot watch with a 2409 movement. It wasn't ticking and to be honest I can't remember if I bought it that way or not. Anyway, with all this extra time on my hands at the moment, I've been watching a lot of WR videos and it has reignited my passion for watch repairs.
I took the 2409 apart and gave it a good service. I have the watch back together and as soon as I inserted the balance the watch started ticking again. Great! It ticked for about 40seconds or so with some noticeable missed click and then stopped. Interestingly, I noticed that the pressing down on the barrel bridge got the watch ticking again. I though perhaps i didn't tighten the screws down properly so I tried resetting the barrel bridge and barrel and still the same problem. I have a several spare parts movement so I tried using a different mainspring barrel thinking perhaps there was something wrong with the mainspring? That made it work a little longer (2 minutes or so) but still the problem persisted and pressing gently down on the barrel bridge kick started the watch again.
I'm going to strip down the watch completely and inspect every part more closely for any sign of defects. Any ideas what may be going on here? Where should i focus my attention?
Thanks again and I look forward to participating in this community.
Thank you NuceJoe, I will keep that in mind, but at this stage I've yet to install the minute wheel.
Watchweasol, thank you so much for that PDF, it really is great. That makes a lot of sense. I changed the whole barrel assembly including the arbour when I swapped out the mainspring. It did work better so perhaps the spare movement also had a problem(not sure of its history). I'll take a close look under a microscope if full light tomorrow morning and report what i see.
Thanks, you've been so helpful already. I'm glad I found this site.
I would look at the leaves of the center wheel pinion. Could be a small piece of dirt that could cause it to stop. Clean all the pinion leaves carefully.
CHeck that the barrel does not tilt when installed. If it does the holes in the barrel bridge or mainplate could be worn slightly, that is why it works when you press down the barrel bridge.
Anilv
Thanks so much for all the great advice.
@anilv I think you may have hit bingo with this comment " barrel bridge or mainplate could be worn slightly, that is why it works when you press down the barrel bridge."
I did notice the mainplate had almost a rut scratched into one area, and I guess subconsciously that's what made me press on the barrel bridge suspecting something might have been amiss here. I have a spare mainplate so I will try that one and see how it performs. Any ideas what would cause that amount of wear? I guess poor servicing history?
Thanks JDRichard, I will take a close look at that as well.
probably wear and tear. Problem with russian watches is that while the movements are good, the cases are pathetic, offering little in the way of protecton from humidity and dust. Hence they require regular servicing.
Anilv
Thanks again Anilv, I agree. I watched a video the other day of someone restoring an old omega seamaster. It looked like that watch had been rolling around in someone's toolkit for years. I was surprised to see how well the case did it's job because the dial and movement where in amazing condition. I remembered thinking that would not be the outcome if that watch had been in a Raketa or Pobeda case. Having said that, I do like the Vostok Amphibia case design, I find those to be very well engineered for diving.
Just to pass more credit where it’s due: then third comment from WW suggests checking the barrel arbor bearings as these cause tilt due to side-shake.
    • Sorry @nickelsilver, I'm just seeing this now.  It is a standard metric screw plate. I followed the suggestion of doing the thread cutting in a pin vise.  It took me forever because the piece is so delicate that I cut and cleared chips very frequently.  But eventually I did get it.  Not pretty, but I got it; the first thing I ever successfully made on the lathe. I cut the screw slot with a jewelers saw.  How can I ensure that the slot is centered on the screw head?
    • Hello, My name is David and I’m a vintage watch collector/ wanna be hobbyist watchmaker from France. I really want to progress into my watch repairing hobby. For now, I’m only having fun servicing my own watches and spare movements, simple small 3 hands from the 50s (Omega, eterna…) Learning step by step or at least trying to 🙂
    • More setbacks and successes...  After letting the watch run in (but before I fixed the BE) a chunk of the radium lume fell off one of the hands and pulverized leaving radioactive dust all over the dial 😞 ☢️ ☠️ So before I could continue further I decided I would remove the radium lume.  I have removed radium lume from hands before where it was already starting to flake away but this time I had to work out what I was going to do with debris on the dial.  I decided that getting everything under water and removing all the lume was probably the best way to go. So here is what I did... I put an essence jar I use for cleaning parts and filled it with water and put it into a big ziplock bag along with the tools I would need - a sharpened piece of pegwood and  a 0.80mm screwdriver  -  I put on a pair of nitrile gloves and a covid style mask and then opened the back of the watch. Now with the back off the watch I could do the rest inside the bag.  I removed the watch from the case and removed the hands from the dial (through the bag) and then undid the dial screws and removed the dial from the movement.  I then put the hands and the dial and the watch case into the water and removed the movement from the bag.  Carefully and slowly with one hand in the bag and one hand trying to poke and hold stuff through the bag I gently rubbed away the lume from the dial and hands with the pegwood. I then took the parts out of the water and removed the jar from the bag (leaving the parts still in the bag) - with the majority of the dangerous stuff now in the water I disposed of this (down the toilet) and gave the jar a good rinse in running water before refilling it and returning it to the bag where I gave all the parts another rinse in the new water.  I then took the parts and put the geiger counter over the top of them and looked at them carefully under UV light to see if there were any flakes still hanging on. I dried everything with some kitchen towel. Once I was finished will all that I remved the parts from then removed the gloves and put them in the bag with the paper towels and the pegwood and thew the bag in the household waste. Finally I gave the dial, hands and case another rinse in the sink under running water.  I didn't bother following up with a rinse in distilled water water because the water here is pretty clear of limescale etc and I find it doesn't mark! So here are the results of my weekends work! Timegrapher dial down (dial up is almost the same) The fixed shock setting New crystal - and lume removed from dial and hands
    • Hi and welcome! I'm new here too—greetings from Leicester, UK.
