3 hours ago, Nucejoe said:
minute repeater
just a really nice  21 J railroad grade pocket watch..
4 hours ago, Davis said:
Is this a beautiful movement or what!! Asking for a friend.
It would be really nice to have the serial number  then I can get you additional information..
1 hour ago, JohnR725 said:
Just a really nice  21 J railroad grade pocket watch.
my bad  just a extremely very nice 23 jewel as they jeweled the barrel assembly..
A thing of beauty!  Love the engine turning and damascening, and gold etched lettering. And look at the regulator! It would be as accurate as it is beautiful. Nice vid.
    • I've gone the threadlocker route having tried the material insert approach without success. The watch runs but I'm chary about winding it more than a turn or so in case the 'repair' gives way; still, there's an element of satisfaction in getting it going at all as it's a single bridge/plate design which I could only assemble dial side up & then flip over in order to be able to insert the 3 securing screws. The reassembly took a number of attempts over many hours but at least I got considerable manipulation practice & the experience will come in useful in future. I'm now faced with my ignorance about how to manually set the the time as this key-wound Waltham pocket watch doesn't have the usual pull-out stem facility. All I can think of doing is to adjust the regulator arm until it catches up with the current time & then revert to the central position.....
    • So the crown should be a 0.9mm thread as you've ordered. How do you know the thread size is wrong if you've not removed the broken stem yet?
    • You'll need to be extra careful with the Citizen as Information along with Parts and Donors are pretty much none existing. You'll probably end up having to use a stem extender, that's hoping there's enough stem left in the movement.
    • Thank you! That's immensely helpful. I appreciate the trouble you've taken. The initial hiccup aside, I do hope to treat this watch with great care and respect. I've certainly learned one thing not to do, and also just the general need to start out very slowly and very carefully.
    • 166.128 is the case reference number and the Omega logo is on the crown. This is the watch.
