Good day, all.
I've completed Mark's coursework 1-3, and I've torn down and reassembled the ETA/Unitas 6497-1 a few times.  I feel comfortable with the pocketwatch's somewhat oversized components.
Could you direct me to a logical second movement to obtain for practice purposes?  I'm not too familiar with date complications, so I'd prefer it be an equivalent of the 6497 (similar components and no date complication/s), but of wristwatch size.  I would not be adverse to a center seconds hand.
Thank you as usual.
Larry.
What is that you like? Get that or similar if too expensive, maybe just not a chrono yet. A complete watch that you can then wear would be ideal IMO, you did good with Mark's and now deserve a reward..
I’m going to suggest, only because it’s was the first automatic I worked on, a Seiko 6309. They are abundant in basic watches, have a very simple automatic winding mech and pretty straight forward keyless, no unruly springs to ping off into oblivion and unless they are completely beat up you can achieve good results.
Disclaimer: I'm a deep end guy. I learn to swim on the kitchen floor (read like crazy until I feel comfortable), then just jump in.
Date complications are tiddlywinks. Nothing to be remotely concerned with. The only thing you might hold off on is something you care about breaking. A chronograph is complicated, but if you're careful and pay close attention, it's not at all impossible.
The approach I backed into mostly because shipping hasn't been all that timely during the pandemic is to fiddle around with what's to hand. I had a collection of crappy old watches that I accumulated years ago; cheap junk, because it's what I could afford in college. Mostly eBay type stuff I thought looked OK at the time, or things that came in lots with other things I actually wanted... That sort of stuff. Nicest and most complicated watch I've messed with out of that lot is a 7S26B Seiko 5 that was broken in a car wreck. Turned out not to be so broken, so I'm actually trying to make it run. Automatic, day, date, center seconds... The only thing that's given me headache is the mainspring barrel was a pain to split and I ended up warping it a bit (I had a spare badly running 7S26C, so lesson learned, part salvaged, moving on), and I roached the hair spring up good. I managed to screw the second hair spring up a bit as well, but I'm not calling it dead yet. The only things that gave me any issue at all are in no way specific or even related to automatic or day/date functionality.
@AndyHull has been playing a game he calls the "404 Club" (I think it refers specifically to a group of watches in his collection, but I'd almost go so far as to advocate it become A Thing™). @FLwatchguy73 and I have been dabbling a bit with the challenge as well. The premise is finding watches for £4.04 (currently $5.08/€4.52) and having fun (it's a hobby after all!). So far, I've managed to score a handful (ten or so) of French and Swiss watches, all fully jeweled (17+)... Well... Mostly... Still waiting on shipping. If I screw any of them up beyond any usability or parts salvageability, I'll be out an absolute max of $15 including shipping. Cheap experience.
That experience moves quickly. The first "modern" watch I dis/reassembled was a Tongji, and I had a **BLEEP** of a time manipulating the shock springs. Last night, I popped the shock springs on and off the Seiko a handful of times with no issues, and first attempt each time. Elapsed working time between the two couldn't have been more than 5 hours (though it's taken me weeks trying to find time with a newborn, two tech professionals working on what has literally become the bandwidth equivalent of an unreliable dial up internet connection, and a pandemic).
Jump in. Break shit. Learn. Move on.
Edited by spectre6000
I would suggest an EB8800. They're a super simple in pallet movement and the are dozens listed on eBay for under $40. These were incredibly common back in the day and parts are readily available.
Thank you all VERY much for the detailed answers.  I've looked at the EB8800 and it looks good for what I'm looking for.  On the other hand, the whole "dive in and break stuff" mentality is just fine if the movement is inexpensive.  I just know it's time to get off pocketwatches.
I'll have a look at the Seiko 6309.
I'm grateful to have a forum that is so helpful.  Thanks a bunch, all!
    • What you’re saying is that if the entire coil is lifted or tilted either up or down it is due to a slight twist in the spring? Usually next to the stud?  I’ve chased this before and in one instance the spring came out of the stud and I had to reinstall it and secure it in place.  Do you find that the angle (not twist) the spring leaves the stud not only affects how it centers in the regulator pins but also the coil spacing? This could be caused by a distortion in the spring as it grabs and release the pins. I find turning the stud counter clockwise opens the coils 180 degrees away from it. So do I adjust the stud in relation to the regulator pins or to the coil spacing?  I also find that unless I remove the balance from the cock I can’t see the slight distortions in the spring. In my picture the distorted spring looked fine when installed. Do you use Alex’s technique of sliding the regulator arm up and down the curve to find distortions or can you visually see them?
    • So if anybody overrides what i say, listen to them haha. I'm not an expert but i've just been in this boat a dozen times as i used to mess up hairsprings bad, but the good part of that was that i got to learn how to fix them.  What made my life SO much easier was learning how to adjust the hairsprings with the balance installed on a disassembled mainplate, unless it's a very serious problem or on an inner coil you can't get to i would recommend trying this in part because the spring will mostly ALWAYS look flat when the balance wheel is not installed on the cock. Install the balance wheel back in the cock and the cock with the cap jewels in the mainplate, with it installed even the most imperceptible twist will be pretty obvious. Just make sure the balance jewels are also installed. In these movements, if 99% of the time any twist or problems gonna be around the terminal curve, twists often near the stud, especially if you've been removing their awfully designed studs from the balance cock. If there's a reliable way to install those things without introducing a minor twist to them i haven't found it. they're an awful design. INstall the balance on you mainplate WITH your capstones/chatones and look sideways across the balance under magnification. Look for the highest or lowest spot of the now not flat hairspring. 180 degrees from that high or low spot is where your twist will be. You have to be VERY careful with twists as the tiniest over or under twist brings it out of flat. If the area i have to untwist is near the stud i just use a pair of #5 tweezers or some very sharp fine curved tweezers and gently see which way i twist it corrects the twist, then i hold the very fine point of the tweezers on the hairspring and just gently squeeze and check it and see if it started to correct it, then i rinse and repeat. Tiny adjustments is what you want, don't close them all the way, and dont' introduce a flat spot in them. it's just a little nudge by closing the tweezers on it at an angle. .  If the twist is not near the stud, i grasp the hairspring with some very fine curved tweezers as gently as possible while still holding it then i do that same sorta tweezer squeeze with my #5's.
    • Has it got the logo on the crown. I think you're best option is going to be to remove the damaged stem and measure it. Edit Do you have the case reference number.
    • Movement is Omega 1012. I bought this from Cousins:
    • Welcome to the WRT forum.
