My New Camera ... Err, I Mean Phone ... No No, I Mean Camera!!
Well, I've gone and done it! :pulling-hair-out:
After years and years of refusing to buy a stinkin mobile contraption, I've succumb to the allure of the darkside.
I need a more portable camera for work, to take reference photos ... something with a high megapixel rating and good macro zooming.  I didn't want to be lugging around a DSLR to work everyday; and beside, there isn't enough room at my workstation for one.
Let me tell ya though, this padawan's resistances was strong.  Spent about 10+ hours researching my opinions, as I was hoping someone out there made just an MP3 Player with a decent camera; but alas, they don't.  Looked at the iTouch, but it's zoom and picture quality totally sucks.  Looked at the Samsung Galaxy Player: same!  iRiver,SanDisk, Zune ... you name it, they all take disgusting photos when it comes to macro zooming.  In ALL the research I did, only one device kept coming up, and fitting the bill ... the Sony Xperia Z3.  The Sony Xperia Z3 Compact to be specific.
The camera specs are impressive to say the least, and make the iPhone and Galaxy look every lame in comparison:
  • 20.7 MP camera with Sony Exmor RS™ for mobile image sensor
  • 8x Digital Zoom
  • 25 mm Wide-angle Sony G Lens
  • Background Defocus Option
  • BIONZ Processing Engine
  • High frame rate - 120 fps - (So you can create clear slow-motion footage of the Balance and Fork running if needed ... very cool indeed!)
It also has a BUTTON on the far right-hand side of the case to work the camera (just like a normal camera) ... you don't have to use the touch screen ... THANK YOU SONY!
So on the weekend I trotted down to the local electrical super-duper store to check it out.  And I was sold!
The macro zoom is so good you can see dirt particles in-between your fingerprints! :o
It's got a Mini SD Card slot, that can accommodate up to a 128Gb card ... so you'll never run out of storage for photos, music, movies ... blah blah blah.
Also, taking about music, it plays every digital format, including all the new 24BIT Hi-Rez formats like FLAC.
Oh, and it also recharges wirelessly like an electric toothbrush!  Just place it on a circular pad, and bingo!
The darkside was just too alluring, sorry Yoda!  I brought one!
Well done for resisting so long Lawson, and that camera sound awesome. I was like that about ten years ago, but gave in when my mum started to go down hill and I had to be contactable.
My first mobile was a wee Sony with 2MP camera and it was a little cracker. Superb camera and so small you were hard pushed to work out what pocket it was in. I then changed it for a larger Sony with more mega pixies and great camera, the only problem it was totally unreliable and a piece of junk. It lasted two days! I exchanged it for the phone I liked best, a Nokia N86. Brilliant camera and real buttons, it just wasn't great for surfing the web, not that that bothered me.
Along came Christmas last year and daughter treated herself to a new IPhone 6. She then gave me her old 5 for my Christmas, great for surfing the web, but what a pile of sh#t€. The trouble is I feel compelled to use seeing as she gave me it. I just really want to reinstate my old Nokia.
Congratulations Lawson, and welcome to the dark side...your camera features are more powerful than mine (Samsung Galaxy S5)...if they were light sabers you would have won already! :)
...OK, that's what I call beautiful pictures Geo! How do you manage?
Cheers,
Bob
Wow - can I play?
Here is a pic done on my old iPhone 3GS - made a silver casting of a plastic earring for fun.
Trip to Kenya taken on a Nokia N95
Trip to BBC studios taken on an old Windows Mobile (iPaq style) phone.
I still want my Nokia back! :)
The camera on the N95 was very good, but the camera on the iPhone 5S has some amazing features including HDR which actually does a reasonable job or sorting out the peaks and the troughs.
And I took this one on a Samsung Galaxy Note when I was in Market Rasen:
  • Similar Content
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
