Invicta Venom Crown Repair
Hello Everyone
I broke the crown for my Invicta Venom 24257 and lost the crown. The photo here it is the way it currently how the stem looks.
I am able to find the replacement crown on the ebay but wanted to know how to replace it. I am a novice, can I do it on my known or it is must to be sent to the repair shop.
Thanks in advance
It depends if when the crown broke off how much of the stem is left. With a shorter stem and the crown screwed on it will not engage the winding and hand setting wheels. However there are such things as stem extenders that can screw onto the original stem that help repairers to over come such a problem, providing enough stem is left to screw one onto, you will need to know the correct screw size. Here is a picture of the extensions I'm talking about.
Hi  It all depends on your skill level and understanding of watches. If you have the tools to get the back off and remove the stem . If not the safest way is the repair shop or as Old hippy advocates using stem extenders.  Inexperienced poking about could lead to a ruined watch or a large repair bill.
Thanks for both the replies, I just had one more question. I have taken off the stems of other watches which had crown still in place, AI pushed the button and pull of the stem with crown , but in this case how do I take the stem off
Can you remove the back and take a picture and we can help you. A shot in the dark, sometimes there is a tiny screw that needs to unscrewed a little to remove the whole stem, or it could be a push in piece you need to push in. By looking at the movement we can pin point the part for you.
    • You need to know at least the basics. Then the questions that You ask will begin to make sense. From what is seen on the video, the gear train and escapement look fine, but the balance doesn't rotate free. I can suppose that the thin gold colored shim that must stay under the balance cock is not in place.
    • Yes, there are a lot of shapes and all of them are used in different cases. The one in Waltham A11 is one of the most spreaded and is what I have shown in the beginning. Of course, the radius of the final curve will depend on the distance between the hole in the stone and the regulator pins on the cock
    • I just found these. They don't really grab my eye at the moment, but having seen the change in some of the watches on here, before & after, the results have been pretty impressive. https://www.ebay.com.au/itm/196382906131?itmmeta=01HXBSJJXDB5J6H916ARJP9PHE&hash=item2db9555713:g:REwAAOSwUNdmOYAZ&itmprp=enc%3AAQAJAAAAwOAlUO3a1pAUX60Y8gUeXMPriraj5e7rkBNH2EA6cIUH7kb7hzoq6jRmOsYOQazk9R%2FteDESr1e50Asabv2tbJyDM%2FVODtmrAScFS4jPhHdgu6Jvt%2BFuRGBijpTkPl4NiK%2FDGr6qztc1Ujb33Tt6YdaUztOH9R1y9XJbwjH0puPDy8m0ilYcal7Vphcp7d59DLtBliNnbqfxfWhxdia2xMRyHYFHzR0Rg7NqB1z4xQGMZb73MAG4QBiF9FMkrII88Q%3D%3D|tkp%3ABk9SR_KuyvnqYw
    • I agree, it's getting harder and harder to find anything that meets the brief other than complete junk, or fake/frankenwatches. I would be in favor of raising the limit so people can continue to enjoy the challenge of resurrecting these low cost watches to their former glory and allowing the watchmaker the ability of practicing new skills without the worry of breaking the bank if all doesn't go to plan. Now all we need to do is settle on a value - maybe base the value on a standard currency so we are all playing by the same rules ($, £, €...?) Unless anyone minds I could start a poll and we could all vote on currency and value... let me know!
    • Same for me, but this is the first time I use the Bestfit. I understand that, for a 17-3/4 caliber, I have to consult page 150, but I can't find any resemblance. Thank you for all your research. I learn a little more each time I use this forum 😀
