Atomic clock vs my computer
Since I just got a circa an early 1990s Longines VHP I've started tracking it to the image of a clock on the NIST Atomic clock site.  I was shocked to see my watch had lost and gained few seconds over 5 days. So today I compared it again and it was -2.74 s. Then I looked more closely at the NIST numerical clock and  image of the clock below it.  They were different, and the clock image was -2.74 and stated "your device's clock is off by 2.74 s". I never imagined the clock image was representing my varying computer clock. Bottom line it it was a relief to learn my watch is right on time and my computer clock varies. Thought I would post this in case others are looking at NIST clock like I did.
Henryr
I often wonder just how precise time needs to be,I have around 80 watches, and thirty clocks and can say that the old adage is very true if you own a clock you know the time if you own more than one you are never quite sure :fpc:
Inaccurate time on PC is due to poor OS implementation which uses a single time server, often also inexact like time.windows.com. Below an article on how to change this setting to a better one, like e.g. uk.pool.ntp.org if you're in the UK, or replace uk with your country code. Doing that I have about 0.3 sec difference with the NIST web page, and that is very normal because of the delay between said USA server and a PC in e.g. Europe.
https://answers.microsoft.com/en-us/windows/forum/windows_10-other_settings/how-to-force-windows-10-time-to-synch-with-a-time/20f3b546-af38-42fb-a2d0-d4df13cc8f43
Edited by jdm
This is very evident when trying to purchase from eBay. You're down to the last few seconds and you place a bid at the last 2 seconds and 5 others bid and you miss out. Turns out there were a couple extra seconds because your computer time and the time on the eBay servers was different. Annoying!
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
