Thks for welcoming me!
FREDCHEN
good day to everyone!
I hope you are all fine and thank you for welcoming me on your forum! I started recently the fantastic lessons from Mark and of course want to go to the next steps!
I am not completely new in watch world as my grand father was in the watch repairing business in his village. So I had chance when I was very young to get familiarized with pieces and tools in his workshop! Few decades later, and under the "pressure" of my son that is becoming addicted as well, I think that it is the right moment for me to develop as hobby this old passion.
My target is to become more knowledgebale and refurbish few vintage watches. I am a big fan of classic model and have already a couple of nice ones.
I hope I will have the chance to keep on talking about my passion with all of you and that my contributions will be appreciated.
All the best to everyone and stay safe!
PS: My favorite brands: Longines, Junghans, Cartier, Chopard and of course TAG&HEUER. - I want to know more about OMEGA, NOMOS, IKEPOD, ORIS, JEAGER...
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
    • No thats straight out of the watch as i found it the balance wheel is almost as bad. I've never seen so much material removed.
