1971 Bulova Deep Sea case back
Newby and first post. Before I go any further with this acquisition, can anyone confirm whether the case back on my Deep Sea is friction fitted or screw down? If a screw down, where might I find the unique case wrench required
Thanks,
Patrick
2 minutes ago, watchweasol said:
 Sorry forgot to mention  They are usually screw down,  A sticky ball will also remove them if they are not too tight again available on ebay.
Thanks for the quick reply. You say they are "usually" a screw down. So is that to say this model has been made with both friction fit and screw down case backs? Sticky ball won't budge it if it is indeed a screw down and my LG case wrench doesn't come with this type of attachment.
Hi Just be aware of the fact that I have seen watches with snap on backs with that design but the  Flats    are not as well defined as the one you have so on that basis I would say its a screw on. Some backs can be well tight and take quite a bit of force.
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
    • Thanks for the info. I can't seem to find tech sheets for those either.  I'll muddle my way though 🙂
