longines bracelet shortening help
Hi all,
I just bought this Longines VHP and am looking for info on how to shorten the bracelet. The watch and bracelet look almost like new so I don't want to scratch it. I looked at the pins on the edge of the links but don't know what type they are and the best way to remove them. Does anyone know how to do this?
Thanks,
henrylr
Here is a picture from a longines bracelet of the same period. This has the arrows on the back, although I can’t see any on yours.
The arrows point in the direction that you push the pins to remove them.
If you have no arrows, then look at the edge of the bracelet. The pins are split at the end that comes out first (i.e. push from the other end)
WOW this is a great site.  I thank you all for the help. What really had me stumped was that on the same edge some pins are slightly recessed and some have a rounded end slightly above the edge.
henrylr
The "ressesed" ones are the links you can shorten the bracelet with, sometimes it is frictions fit pins and sometimes it is screws.
In this case it is pins you push out with a link shortening tool like this.
The others is just there to hold the bracelet together, most often the links you can shorten the bracelet with have the same size and the others can get slightly bigger with distance. Like from 18mm to 20mm at the case.
Edited by HSL
Thanks for your help and info on the curve topped pins. I ordered a pin remover like the one in your photo. And I just remembered an answer I got from another watch forum. It said the curved tops were covers that needed to be removed to get at the pins. I'm very glad I found this site and didn't try to pry off something that wasn't there.
I don't want to make misleading statements and maybe the person that told me the pins had removable caps might be correct for some VHP bracelets. The attached pic shows a VHP with what look like caps on both edges of the bracelet. Look at pic closely.882297322_vhpband.thumb.jpg.6d1046638d1a66142aafc05cbab1ace8.jpg
henrylr
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
