I took apart the balance and balance cock today and found a half round shim under the balance cock. Although without the shim it doesn't work, isn't this just a patch someone put in there for a problem? Looks like the balance drags when th shim isn't there.
Since I'm new at this why would someone shim a balance cock?
waltham 1883 open face 18s
Lee
The balance staff is possibly a touch to long. The shim is a common fix used by many watch repairers and should not cause any issues if put back in the same position.
Maybe to adjust the end shake after replacing a broken balance staff where the replacement was slightly too long.
You beat me to it Clockboy :-)
I agree with Clockboy and Marc.
Another possibility could be that oil in the base of the balance jewels has turned into a a hard varnish over time and has not been cleaned out properly at the last service. The varnish can swell with both the cleaner and fresh oil, resulting in lack of clearance and a tight balance shaft. I have had this problem with a couple of old watches with fixed balance jewels in the past.
Anilv is right
Just about all the common russian sekondas (19 jewel through to 23 jewel) have them fitted, I have also seen them double stacked under the balance cock as well...
Darren
