Hi,
I have a Bell & Ross BR03-51 GMT carbon fiber watch with a date disc that keeps coming out of alignment. It appears the wheel between the two large date discs has two broken teeth and will need a replacement part. But for the life of me I cannot find information (via the internet) on the technical documentation of this movement. It’s a modified ETA2892 with a Technotime TT651 module on top.
When I realign the date discs, they flip and align fine - I’ve quick date set for about 6-months of date changes. It must be the date driving wheel interacting with those broken teeth that cause the issue.
Anyways, if anyone can help with documentation so I can attempt to order the part from someone (somewhere) it would be greatly appreciated!
TIA! C99D4C91-4A8B-4E6F-AE34-98518903B59D.thumb.jpeg.493d3e3dbdf8925de88c84ba633e0448.jpeg617B2E22-7FB2-4A10-9DED-C388E7D64B1D.jpeg.305eb1b1997136b6f7326333f30596fe.jpeg
If Technotime is like Dubois Depraz or Bell&Ross is like most other Swiss makers, they will not sell parts to anyone. You can, of course, contact them directly as a "qualified independent watchmaker" and try your luck.
Edited by jdm
Can you show more of the mechanism? I have a sneaking suspicion that those teeth are missing for a reason. Both discs only jump at the same time on some jumps, on others the left hand one doesn't. How that works remains to be seen.
I had the same suspicion as you! But ended up doubting my instincts because I fixed this once (dates were out of sync). Checked it. Reassembled. And a month later the dates were out of sync.
on closer inspection, this wheel is actually two wheels stacked. Both with appropriately missing teeth to allow either date disc to flip at the right time.
So, in the end, I don’t think (right now) I need a new part. What I need to do is solve why this reoccurred.
here’s the extra pictures.
Ok!
To me it looks like there is quite little room between the wheels in the stack, and the wheels are quite thin; my first thought is that the discs may have a hair too much play on their tenons, and be tilting during a jump sometime, either causing a misjump or making one jump that shouldn't. Could we see what the underside of the discs look like? Another possibility is jumper tension; I think the discs are in engagement with the wheel stack in general, except when on a 'missing tooth' time, if the jumper tension is too light, or again if there is some play and the discs can come out of engagement with the jumper, then you'll go out of synch. Of course if the jumper tension is too high, you'll lose amplitude or stop the watch...
Edited by nickelsilver
What is the normal amplitude loss when a calendar or crono module rides on the like of  a 2892?
I didn't had a chance yet to work on those.
Ha, I honestly don't know, but I think it is practically nothing. The date wheel takes a while to pull the date disc around. On some watches with instantaneous systems you might see 5-10 degrees drop while it's arming the system.
On 3/19/2020 at 9:32 AM, nickelsilver said:
Ok!
Here’s a few more pictures. I toyed with the tightness of the springs. The date flips with a secure “snap”. Looks very good to my eye. I’ll test this against the Timegrapher to see if there is a dip in amplitude - and report what I find.
  • 4 years later...
Did you by any chance take pictures of the reassembly that can be referenced for service? I am going to attempt servicing this movement and could really use the help. Thanks’
On 12/31/2024 at 10:04 AM, AndyGSi said:
Have you looked at the details for the ETA 2892.A2 that it's based on?
https://www.cousinsuk.com/document/search?SearchString=2892
Yes i got these docs from Cousins earlier and I have worked on a clone 2892.a2 that i purchased from cousins too. However, I am attempting to work on a Tag Calibre 8 GMT and the GMT and calendar works are driven by the TT651. I have also downloaded the technical sheet for TT651 from cousins but it would be ideal to see pics of reassembly if available.
