omega 565 keyless
Hey
Can anyone tell me were i am going wrong on the keyless works on this omega 565.
Pic 1&2 shows the castle wheel connected to the crown wheel so if i was to wind it would.
pic 3&4 shows with the castle wheel end weight (sorry dont know name for this bit its new to me) but you can see the bit added.
pic 5 shows the setting bridge fitted correct to the plate.
Pic 6&7 shows how its got to be or the castle wheel will not engage the crown wheel and wind up.
Any clues would be a great help.
I have a sheet with parts named on it for the 565 but no exploded view sheets or anything on the keyless set up.
cheers
gary
There is certainly a difference between the two. The one in the video had three steps on the stem, yours has two, and yours has the cam in a different position, despite the fact that they both appear to be in the "crown in" winding position.
2 hours ago, Watchtime said:
Seems like a difefrent lever to me or am I wrong? In the video it has 3 positions, the OP's has 2...
The cam/lever looks different and the spring plate looks different (2 vs 3 notches). I suspect the version in the video has day or day/date complication with a day quickset, the other does not, hence the 3rd crown position and the three notch spring.
The cam with the pin sticking up, that rides on the spring, and that has the second pin that is not connected to anything in the pictures (but may be related to the day/date),  however is in a different orientation, so that may be the issue. Difficult to be certain that this is the issue, but those are the  differences I can see.
Edited by AndyHull
Hi
Once again thanks every body I will try leaving the cam off and see how that goes. This version just has the date on it. So I guess I need to find out which bridge is for what movement.
Bad day to give up smoking.
Cheers
Gary
    • Hello everyone, My name is Matt and I like vintage watches along with pocket watches. I'm very new to the hobby of watchmaking, I've only been tinkering for about 2 months and I'm happy with some of the projects I've salvaged.  First I repaired This Waltham 17 jewel 18s and that was fun.  Then I repaired this old Zenith movement with 19 jewels. I couldn't find it on the pocket watch database though.  Then I repaired this one Lucerne 1 JEWEL movement. It was actually the first watch I got but it was so difficult to put back together with the fiscal amount of tools I had at the time so I just left it strewn in a Ziplock bag. Then My most recent project that came up a total win was this Longines Caliber 19AS, 17 jewels unadjusted. It turned out beautifully in my opinion and was by far the most difficult to reassemble.  I am in love with this hobby and its kind of engulfed my personality as of right now.  I plan on giving the Longines watch to my uncle, and so right now I'm trying to enjoy that watch the most I possibly can.    What I'm currently working on: A Seiko Automatic with a little date window and a weekday function too. I think its the 6309A.  Then there is this Omega pocket watch. Unfortunately I lost a little screw that held in the click spring. I'll have to source another one because its tiny and my room is filled with carpet, that thing is gone. Then theres this little tiny Elgin pocket watch. It's fully assembled but the amplitude is low and so I think it needs a new mainspring.  Then theres this Waltham 7 jewel movement that I also cleaned and reassembled, but it'll only run facing one way and again with the amplitude being low, I think it needs a new mainspring as well.  And finally, I'm working on this gorgeous Grade no.3 1883 Waltham Pocket Watch. It came with a broken balance staff on both sides and would only run when the watch was like sideways, crown to the sky. I'm really excited about that one though, might be worth something.      I've chosen to not show the other ones because they're not in movement holders right now, and the Omega is not put together.  As you can see, I take these pictures using the flash. Idk why but I like the way the flash makes the metal shine more than just my little lamp.  I'm also very eager to find a replacement for that balance wheel; any links would be appreciated.  From what I could tell on the Seiko, it's just dirty and It should run if I put it together carefully after cleaning.  Also, I fear that that 1883 Waltham may not run too good because of the mainspring, it's probably set because it's so old. I may seek a replacement for that too. I also need to find a crystal for that 18s gold filled Waltham that I've put together. It's just scary having it exposed.      I ALMOST FORGOT to mention. Is this Omega real?      You gotta turn your head a bit but it does indeed say "OMEGA", so I'm confused. I never knew they made pocket watches. And thats why I'm skeptical. Please let me know.    But thats pretty much it. I just wanted to put this out there so that I could begin using the website properly and also to let some people know I exist I guess.  Also this is my second account. I know that may violate some rules but I did the introduction wrong the first time and I wanted to fix it by making a new account. Please don't ban this one.    Thank you all, -Matt
    • Sounds like you and @VWatchie were unlucky. Mine has been running on 230V UK for years  ( it's been 230V for many years @Neverenoughwatches, not 240V).  Though I have had to re-solder some wires. When I buy cheap Chinese electrical components I often take them apart to check they're not going to kill me. Since the demagnetiser, I bought a cheap fish tank heater for my plating set up. Plugged in, big flash and smell of burning. Deader. So I bought a cheap cup heater plate. Exactly the same - flash, bang, wallop.
    • The old crystal is cracked on the edge, and I am looking for something like for like.
