Baumgartner BFG 866
  • 2 months later...
Hey, thanks for this. I've read through it twice now, because part of my interest is in jump hour watches. I only have one BFG 866 jump hour, but i have two BFG 582 jump hour, and two UMF 24-34 which as you know is a similar design.
I have a question about lubrication.
Ironically, my BFG 866 jump hour is the 21J variation. But most of these are 1 or 0 jewel movements. I have maybe half a dozen 866 3-hand movements.
It seems like the pivot-to-bearing area is larger in these than in jeweled movements, because the bearing is thicker, so perhaps slightly more oil is called for?
And i have to wonder if the same viscosity is warranted as with jeweled pivot movements in the same size. Specifically i wonder if something heavier than 9010 might be better?
My BFG 582 movements seemed to have been liberally lubricated with a mixture of 3-in-1 and Mel-Fry which had polymerized into a stiff goop which appears to have been why they stopped working. The bearings don't look ovaled-out like the ones on my UMF 24 movements. Short-lived lubricants for the win?
Edited by TimpanogosSlim
On 10/23/2020 at 2:21 PM, Jon said:
I've just posted a PowerPoint presentation of removing and re-fitting the friction fitted minute wheel.
Hope it helps. Any questions, don't hesitate to ask, as I expand on the lesson in the class room, so end up explaining more than is in the pictures and captions
Hi can you explain what a "tight fit" on the collet means?  Does it mean that the minute wheel can turn on the collet, or does it need to remain stationary and only turn with the barrel?
With the 'tight fit' you should be able to turn the minute wheel on the barrel with your finger and thumb. The tighter it is, the tighter it feels when you 'hand set' the hands and looser that friction is, will feel sloppy and loose when setting the hands. It takes a bit of practice to find that 'Goldilocks' spot of how much friction to create with the staking tool.
Thanks, that's very helpful.  I am refurbishing my second one of these now.  On the first one, I didn't mess with this part because I didn't know that the wheel could be removed.  That watch is running nicely.  The current one went together much easier (owing to my being more familiar with the movement) but the hour and minute hands wouldn't turn.  I had originally put the minute on so that it turned freely with almost no resistance after seeing that the wheel could be removed.  I'm not sure if installing it so loose would cause this problem.  I've disassembled it again and armed with this information, we'll see if it makes a difference after an adjustment.
The finished first watch is below.  The second has a nice case but the dial has been relumed and isn't quite as nice as this one.
  • 2 years later...
On 3/17/2020 at 10:51 AM, Jon said:
Hi,
I teach watchmaking to complete beginners at Epping Forest Horology Centre, close to Epping and this is one of the lessons on the BFG 866.
I wanted to show my class a classic pin pallet (Roskopf) movement and how to service it, as many watchmakers won't touch these watches as they hold no monetary value.
Turn the setting lever screw 1 to 1 and a half turns to release the winding stem
A piece of watch paper or small plastic jiffy bag to protect the dial, whilst removing the hands
The driving pinion is part of the friction fitted minute wheel on top of the barrel. This work in a similar way to a friction fitted canon pinion to set the watch hands
Remove the keyless work: setting lever, held in place by the setting lever screw, screwed from the other side of the mainplate, then the yoke, which sits on top of the clutch (castle) and also the winding pinion.
I have three other lessons on this movement that cover bringing the watch 'into beat' as well as taking apart the friction fitted minute wheel from the barrel, lubricating and staking back on to achieve the correct friction setting and finally how to remove the centre seconds wheel safely and refit using a staking set. Many people leave the friction fitted minute wheel on top of the barrel, not realising the amount of old grease that can't be cleaned out from it, as well as not removing the wheel of the centre seconds arbor and again not cleaning out the pipe which has old grease inside.
Hope you enjoyed the tutorial? More to come....
Hi Jon
This is great! A watch with this movement has just arrived so this is very handy. The stem is floating in and out so I suspect a setting lever spring issue as you described. Thanks again.
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and with the disk hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and it has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 Very happy how this worked for me 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
