Impossible case back
I recently bought an old, non-functioning Zenith Surf thinking it would be my new restoration and repair project. However, the case back has proven impossible to remove. It's a normal looking screw-down case and I've tried using a typical jaxa tool without luck. I tried soaking the backside of the case in GT7, thinking it might have rusted shut, even thought there is no visible sign of rust or water damage elsewhere or on the dial, that didn't do much either. I tried the good old method of using superglue and a nut, putting the case in a caseholder and placing that in a vise. The case back still won't budge, and I ended up breaking the caseholder into pieces. How common is it for a stainless steel case back to be galled shut? And is there anything that can be done about it short of destroying the case? I guess someone could also have glued the case back from the inside, but that doesn't make a whole lot of sense to me. I guess a gasket could also serve as an adhesive, but considering the force I've applied to opening it, I can't imagine that would be it either.
Any sort of tips or possible solutions are most welcome.
A picture could help. Some case backs are designed to look like screw back but are in fact snap backs. Looking at this one on eBay I might be correct. Looking at the inner rim of the case back is, what looks like a spring washer.
https://www.ebay.co.uk/itm/Very-Rare-Zenith-Surf-solid-18ctl-Hand-Winding-Watch-with-cal-2572/274296780437?hash=item3fdd5cb695:g:SSsAAOSwUcteMuQP
I did consider that, but I kinda figured it would move a bit if that was the case. I did try with a caseback knife just now, and it feels like I would just break that tool as well if I apply more pressure. Anywho, adding some pictures. Excuse the obfuscating bolt (the nut broke off, so ended up trying something with a larger surface area to put glue on).
IMG_0884.thumb.JPG.0801af73b8c122e118f945d066c9117f.JPGIMG_0886.thumb.JPG.644f37917085c41ee30a5c650cdaaa9e.JPGIMG_0889.thumb.JPG.97e3212c58a716389a5cf5496a87ff44.JPG
Hi Judging by the methods used up to now this is a real sticker.  I had a screw back that was cross threaded but it Gave in to the   glue / nut system. I would have thought  if it was a snap back it would have moved a little. It is conceivable that the case back gasket has perished and glued the back on.  The only chance is to soak the back of the watch in some  acetone/spirit in the hope it will soften.  wish you the best of luck on that one           Cheers
Actually looking at the HR image I can almost see threading. A spring washer does not imply a snap back, it's simply one way to keep the casing ring well pressed. Faking a screw back may be common on today cheapies, not a a nice vintage Zenith.
Now if the case holder broke one has to get with a better one, like two metal blocks screwed on a base. Also try to apply controlled heat around on the case, like "almost too hot to touch". The reason why certain butchers glue casebacks is because they want the customer to come back to them in desperation.
A 40w soldering iron with a flat tip would do. Be very careful, don't apply more than 5 seconds to three points around. Ideally check temperature with a multimeter probe, these are very cheap now.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
    • A lot of it has to do with a generations attitude.  Have we reached a generation of folk yet that have no sentimental values ie. Just an object to sell . I expect my kids will sell my collection , maybe keep one valued piece. Not being in the game very long, i have no idea when the sale of old watches boomed or if it has even reached its peak yet. If we go back 20 years what were ebay sales like then, expense wise and volume ?
    • can I ask why you're not happy? did you notice that the acceptable low 24 hour amplitude of this watch is 160°? is there any possibility that a watch company could manufacture a watch that could actually run at a low amplitude and keep time? so if they can run at 160° at 24 hours and keep time then they probably would keep time at 240° which yours seems to be doing? then if you're really unhappy with this I would recommend purchasing an original Omega mainspring. Just because the aftermarket have numbers like an Omega mainspring it doesn't mean it's the same thing. Then I would also recommend replacing the escape wheel and the pallet fork. This is what they do in the Swatch group service center if they are unhappy with anything on the other hand they have an infinite supply of spare parts.
    • That was reason for asking for mark's input, i wasn't sure if going ahead with dealing with the contact information would be particularly well received. @oldhippy thoughts ?
    • @JohnR725 has pointed out many times that the Swiss don't care about amplitude, the timekeeping is the most important.  Give yourself a  pat on the back, great beat error and timekeeping, nothing to be disappointed about.
